Salta al contenuto principale
L'Huawei Ascend P7 è uno smartphone da 5" rilasciato da Huawei nel giugno del 2014. Numeri di modello: P7-L10, P7-L00.
No Service No network
Hello.
My phone has been off for 2 days, fully charged it. and when i switch it on it ready no service... Cannot make calls nothing. Re-started still noting did Factory reset.. Still nothing.
Please help!!!
Thanks
Questa è una buona domanda?
Punteggio 57
9 Commenti
My phones signal is gone for a while now
da Condividi
my mate7 has 1 month no signal, please help.
da Condividi
My Huawei honor p7i network is nt working please how do I do please help me out
da Condividi
My huawei phone is falling in the "no service "
How to relieve this
da Condividi
I just order a huawei honour 5 I install a sim but no signals
da Condividi
Mostra 4 altri commenti
Aggiungi un commento
31 Risposte
Risposta più utile
1) check the SIM card is working properly
2) Check with your operator whether your IMEI blacklisted or not
3) update the firmware if available via OTA
4) Change the network mode : GSM only if signal comes change the network mode to 3G only if you found same issue the one of transceiver not working properly
Punteggio 14
5 Commenti:
It wasnt helpful but the tranciever bit how do I fix it myself
da Condividi
How you did that my honor 9 its the some problem pleas
da Condividi
i have huawei honor 5x..sim its ok can detect,no problem..but signal no services..why yaa.. plis help me..
da Condividi
Sir
My mobile can not show the Sim he show no service plz help me my mobile y 7 prime 2019
da Condividi
I'm using Huawei Y5 2019 I've been struggling with network problems, it says cellular network is unavailable, try using wireless network to make a call
da Condividi
huawei p7 wifi not working
Punteggio 5
3 Commenti:
Huawei p6 mobile network not working
da Condividi
Does your sims cards working please
da Condividi
I have Huawei y7 had network issues, I could not access internet, I just removed data saver and I was back,what I don't understand out of nowhere my phone started to have irritating issues NO NETWORK, I hope the magic works on you, next time I will definitely get another brand, I tend to believe Huawei phones are not reliable to its users
da Condividi
Punteggio 5
1 Commento:
vai no Service network my mobile huawei scl-u31
da Condividi
mobile network not available in huawei mobile
i have huawei honor 4C . It dipped into water at night and i did not care in night. When i open it in morning sim jackets have water drops. Mobile is working properly but not the sim card. When i reinsert sim it says mobile network not available. I did factory rest but in vein.
Network options is also missing in phone now.
Please help me. i just bought few days before.
i am very Sad :(
should i sale it :(
Punteggio 3
2 Commenti:
Same problem huawei p8lite
da Condividi
Same problem
da Condividi
I have a Huawei Ascend phone. was on a call yesterday and reception cut out no reception since in christchurch nz middle of the city!
Punteggio 2
Huawei Ascend G700 no network
Punteggio 1
i have huawei honour 4C . It dipped into water at night and i did not care in night. When i open it in morning sim jackets have water drops. I removed water drops. Mobile is working properly but not the sim card. When i reinsert sim it says mobile network not available. I did factory rest but in vein.
Punteggio 1
Huaweiy330-u11 when inserted SIM it say emergencycall how to fix this problem ?
Punteggio 1
Try to turn on airplane mode, then turn it off. It helps me when i lose network signal
Punteggio 1
Network wcdma not work
Punteggio 1
how can i do how can ido
Punteggio 1
Huawei p20 lite no service
Punteggio 1
Huawei Mobile IC network is default
Punteggio 1
i got lycamobile sim card
when i put in on my phone called huawei p6
and when i want call some in said no service but for anther phone he does work but on huawei not why please help
what can i do make it work
Punteggio 0
huawei p8 lite no net appear after ten days i try all options no hope
Punteggio 0
1 Commento:
no net work shown i restart many times i remove sim many times ...still the same pls your help it's ten days back parched >>
da Condividi
no service max mobile 424 model
Punteggio 0
My sim app is no long in my huawei so I don't have any sim setting it says only emergency calls only and I don't have any network show in my phone ?
Punteggio 0
How to set Sim menagement?
Punteggio 0
I Have This Problem Too
Punteggio 0
honor v9 no service how to this problam fix
Punteggio 0
Remove sim n put it back.
Punteggio 0
try hard reset if nothing's happen is the problem of your cellphone is crystal ic or antenna
Punteggio 0
Falling in water and when on then no service its taking Sim but no signal
Punteggio 0
1 Commento:
i have this problem too
da Condividi
How do I get my new handset working it isn’t reading
Update (04/06/2019)
I just brought a phone it’s not reading my network or service rovider
Punteggio 0
Mate 20 lite Huawei no service :'( android 9.1.0.225
Punteggio 0
my huawei 3i fall into water when it fix it comes another problem no service appears i can't use it anymore i tried all the recommended steps but it didn't work please help
Punteggio 0
how to fix no service for huawei y7 prime 2019
Punteggio 0
2 Commenti:
please help me with this
da Condividi
to my email yasirbofa@gmail.com
da Condividi
Network is not working
Punteggio 0
When my phone is no service Huawei nova 8i how can i do?.
Punteggio 0
How can i do about myself
Punteggio 0
No my phone yesterday will be damping in whater after fixed my phone cam no service even put sim card
Punteggio 0
Aggiungi la tua risposta
muzithembekwayo88 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 6
Ultimi 30 giorni: 35
Tutti i Tempi: 116,092
