Salta al contenuto principale
A widescreen 15.4" notebook computer by Compaq released May 2006.
computer doesn't start up
It wont start up. Only see a blinking cursor on a black screen. By pressing F10 while booting up I enter the setup. Here I see for the diagnose the options for selftest harddrive. Everything seems ok. I try to reinstall the windows xp by cd. The cd starts up but then the computer says there is no harddrive. What can go wrong?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
De Cuyper, sounds like a bad hard drive to me. Try to see if the hard drive shows up in the BIOS. Make sure it is properly connected. Most likely so you will need a new hard drive.
Punteggio 2
1 Commento:
In the bios I can check if there should be a problem with my HD. This seems to be ok. But when trying to install the windows XP the computer sais there is no HD. I connected the hd extern and I can see the HD is ok.
da
Aggiungi la tua risposta
De Cuyper sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 467
