Salta al contenuto principale
Rilasciato nel 2010, il Logitech G27 è un volante elettronico progettato per i videogiochi di simulazione di guida su PC, PS2 e PS3.
LOGITECH G27 Racing Wheel
my g27 wheel has no force feedback and the shifter and clutch pedals don't work. The wheel works and all the buttons work. Thinking it might be the motor?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta più utile
Hi, Regarding your wheels lack of force feedback, it could be that the motors in your wheel are either broken or stripped. However I would check in-game settings to make sure before disassembling your wheel. As for the shifter and clutch pedal I can think of only two things that would make those not work. Either the potentiometer in the shifter is broken and needs to be replaced, or the whole setup is having a connectivity problem with your gaming device. The potentiometer can be replaced relatively easily however the connection problem would be much harder to find then solve.
Punteggio 1
you're mum lol
Punteggio 0
Could be the power supply.
Punteggio 0
Aggiungi la tua risposta
meemo39 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 22
Tutti i Tempi: 828
