Salta al contenuto principale
Macinacaffè a singolo comando Krups identificato come modello F203.
How do you clean it?
The residue of the coffee beans is still in the grinder and hurting its effectiveness.
Questa è una buona domanda?
Punteggio 7
Aggiungi un commento
3 Risposte
Risposta più utile
You can also put in dry white rice and grind it to a powder. Dump that, use a brush or a towel to wipe it out, and the grinder will be even cleaner and ready for something else to grind.
Punteggio 3
Use a paint brush (about 1/2 inch wide) to brush out the ground coffee, then use a damp paper towel to clean up the fine powder. This method works very well, especially if you use a soft brush. Keep the brush near the grinder and brush out the grinder after each use.
Punteggio 2
Sweep a clean dry Popsicle stick around the where the blade built up a residue a few times and get your money's worth of coffee. That's where the oily flavor is. Then dump it in the brewing basket. Use the other hints above for a final more thorough cleaning. Go for the flavor first. :)
Punteggio 0
Aggiungi la tua risposta
Brian Wolfskill sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 41
Tutti i Tempi: 15,394
