Salta al contenuto principale
La versione aggiornata del Nintendo 3DS da parte di Nintendo. Presenta schermi più grandi, una maggiore durata della batteria, una densità di pixel migliorata e un design più curato.
My upper LCD screen doesn't have backlight
Hi, this problem appeared yesterday. I was playing some Smash Bros. and suddenly my upper screen went black. 1 minute after that it shut down with a popping sound.
The screen is still working, I can see images if I lit it up with a flashlight, so it's just my backlight that doesn't work.
I reconnected ALL the connections inside my 3DS XL and rebooted it, but the same problem was still there.
Should I buy an entire new LCD for this or am I missing something?
Thanks for everything.
EDIT: I replaced the LCD screen for a new one and the console still has the EXACT SAME PROBLEM. I really have no idea of what could it be now.
Questa è una buona domanda?
Punteggio -1
1 Commento:
Have you replaced the speaker ribbon cable? If you take off the back of the top case you will be able to see where the speaker ribbon cable goes through the metal tube. Many times there is a small tear in this cable that causes this problem.
da
Aggiungi un commento
2 Risposte
I'd recommend a new LCD, since the Backlight is integrated into it and it is nearly impossible to fix a display.
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
Did you manage to solve this problem? I'm in the same situation.
Punteggio 0
Aggiungi la tua risposta
Gorrin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 468
