Salta al contenuto principale
Repair guides and support for the LeapFrog LeapPad2 Explorer 32610 learning tablet.
Why is there no sound?
The volume is up fully and will not produce any noise! Help!
Questa è una buona domanda?
Punteggio 1
4 Commenti
What is the exact model of phone you have? That way I will be able to further help you know what the exact problem is with your phone.
da
@computeripodrepair, LeapFrog LeapPad2 Explorer is a childrens learning tablet, not a phone!
da
Andrew Gough, what have you tried so far? how long has this been going on? Has anything happened just prior to it failing?
da
My daughter own is the same problem no sound
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
You might have a bad speaker or audio jack. In the case of the speaker you would need to check the connection between the speaker and motherboard. If it was due to the audio jack, cleaning it with an air duster may help. Check out the Troubleshooting page if you any issues.
Punteggio 2
Aggiungi la tua risposta
Andrew Gough sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 26
Tutti i Tempi: 6,509
