Salta al contenuto principale
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Why my controller doesn't connect to my PS3?
I spoiled water on my controller and then the arrows were not working. So I open it and cleaned it up but now, it won't connect to my PS3.. the LEDS keeps flashing and flashing...
Could you help me ?
Questa è una buona domanda?
Punteggio -1
6 Commenti
How did you clean it? Did you check the components while you cleaned it?
da
How I do ? i already tried to reset the controller and its not working with the USB cable ...
da
all the components are fine they have no breaks or anything
da
yes, I was wondering how you cleaned it.
da
with a scott towel
da
Mostra 1 altro commento
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Nicolas, any time you have any electronic component being exposed to water you are running the risk of shortcircuiting any component. I suggest you totally disassemble the controller, after that soak all the components in high grade, preferably anything of 90% isopropyl alcohol. this will displace all the water that may have collected under any of the components. Air dry it after and re-evaluate. Do keep in mind, that just because the components look okay, their internal function may have failed. Not every short circuited component shows external damage. Scott Towels are great for gross contamination, but most certainly not for the microscopic one.
Punteggio 1
you may need to re sync it to the console.
Punteggio 0
Aggiungi la tua risposta
Nicolas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 886
