Salta al contenuto principale
Samsung Galaxy Watch3 Display Replacement
Cosa ti serve
  1. Samsung Galaxy Watch3 Display Replacement, Unfasten the back cover screws: passo 1, immagine 1 di 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Galaxy Watch3 Display Replacement, Wedge open the back cover: passo 2, immagine 1 di 2 Samsung Galaxy Watch3 Display Replacement, Wedge open the back cover: passo 2, immagine 2 di 2
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Galaxy Watch3 Display Replacement, Disconnect the sensor flex cable: passo 3, immagine 1 di 3 Samsung Galaxy Watch3 Display Replacement, Disconnect the sensor flex cable: passo 3, immagine 2 di 3 Samsung Galaxy Watch3 Display Replacement, Disconnect the sensor flex cable: passo 3, immagine 3 di 3
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Galaxy Watch3 Display Replacement, Remove the back cover: passo 4, immagine 1 di 2 Samsung Galaxy Watch3 Display Replacement, Remove the back cover: passo 4, immagine 2 di 2
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Galaxy Watch3 Display Replacement, Unplug the display connector: passo 5, immagine 1 di 2 Samsung Galaxy Watch3 Display Replacement, Unplug the display connector: passo 5, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Galaxy Watch3 Display Replacement, Loosen the core assembly: passo 6, immagine 1 di 2 Samsung Galaxy Watch3 Display Replacement, Loosen the core assembly: passo 6, immagine 2 di 2
    • The core's plastic frame fits tightly within the watch's metal housing.
    • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Galaxy Watch3 Display Replacement, Remove the core assembly: passo 7, immagine 1 di 3 Samsung Galaxy Watch3 Display Replacement, Remove the core assembly: passo 7, immagine 2 di 3 Samsung Galaxy Watch3 Display Replacement, Remove the core assembly: passo 7, immagine 3 di 3
    • Carefully thread the display flex cable through the gap on the core's plastic frame.
    • Remove the core assembly.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Galaxy Watch3 Display Replacement, Push out the display: passo 8, immagine 1 di 2 Samsung Galaxy Watch3 Display Replacement, Push out the display: passo 8, immagine 2 di 2
    • If your display is cracked, keep glass shards contained by applying a strip of tape over the glass."
    • Use your finger to steadily push the display down through the watch's metal housing to loosen the adhesive.
    • Lightly heating the display with a hair dryer or iOpener can help soften the adhesive.
    • Remove the display.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
If possible, turn on your device and test your repair before reassembly.
Altre 3 persone hanno completato questa guida.
Tobias Isakeit
Membro da: 03/31/14
134.397 Reputazione
189 guide realizzate
Tobias Isakeit - Repairability Engineer Membro di Tobias Isakeit - Repairability Engineer
Business
Membro di 1
1.238 guide realizzate
1Commento della guida
Any idea how to remove the rotating bezel?
Azhar Suhaimi - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 23
Ultimi 30 giorni: 144
Tutti i Tempi: 11,462
