Introduzione
Use this guide to replace the heat sink in your MacBook Pro 14" 2021.
Replacing the heat sink requires you to remove the entire logic board.
For your safety, discharge the battery below 25% before disassembling your MacBook. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You will need replacement thermal paste to complete this repair.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:FixMat$36.95
Use a P5 Pentalobe driver to remove eight screws securing the lower case:
Four 9.3 mm screws
Four 5 mm screws
Press a suction handle into place near the front edge of the lower case, between the screw holes.
Pull up on the suction handle to create a small gap under the lower case.
Insert an opening pick into the gap you just created.
Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
Repeat the previous step on the other side, using an opening pick to to release the second clip.
Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
Remove the lower case.
Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
Peel back any tape covering the battery board data cable connector on the logic board.
Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
Use a T3 Torx driver to remove the two 2.1 mm‑long 3IP Torx Plus screws securing the trackpad cable bracket to the logic board.
Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
Peel the trackpad cable away from the device, making sure to separate the adhesive.
Peel back any tape covering the battery board data cable connector under the large pancake screw.
Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
Remove the battery board data cable.
Use a T5 Torx driver to remove the 3.8 mm 5IP Torx Plus wide-head screw securing the battery power connector.
Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
Use a T3 Torx screwdriver to remove the three 2.1 mm screws securing the antenna board bracket and coaxial cable cover to the frame.
Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
Repeat for the two other cables.
Use a T3 Torx driver to remove the four 2.1 mm screws securing the screen cable covers.
Use tweezers, or your fingers, to remove the two screen cable covers from the logic board.
Use the flat end of a spudger to pry up and disconnect the right-most screen cable press connectors secured to the logic board.
Use a T3 Torx driver to remove the nine 2.1 mm screws securing the right cable covers to the frame:
Use tweezers, or your fingers, to remove the five right cable covers.
Use a spudger to pry up and disconnect the headphone jack's press connector.
Use a spudger to pry up and disconnect the right USB-C ports' press connectors.
Use a spudger to pry up and disconnect the MagSafe port's press connector.
Use a spudger to pry up and disconnect the lid angle sensor's press connector.
Use a T3 Torx driver to remove the four screws securing the left cable covers to the frame:
Two 2 mm screws
Two 2.1 mm screw
Use tweezers, or your fingers, to remove the two left cable covers.
Use a spudger to pry up and disconnect the left USB-C port's press connector.
Use a spudger to pry up and disconnect the Touch ID sensor's press connector near the top left of the device.
Peel back any tape covering the keyboard and keyboard backlight cable connectors.
Pull the fan cable away from the logic board with tweezers to separate the adhesive.
Use a T5 Torx driver to remove the 11 screws securing the logic board:
Four 3.6 mm screws
Two 4.5 mm screws
Two 5.2 mm screws
Two 3.8 mm screws
One 3.9 mm screw
Insert a spudger between the right side of the logic board and the frame.
Pry up with the spudger to release the logic board from its clips.
Gently lift up the logic board by its right side to release it from its alignment pegs.
Pull the logic board away from the left side of the device to separate the HDMI and SDXC ports from their slots in the frame.
Remove the logic board.
Make sure all 17 connectors are above the logic board before securing it back into the frame.
Hold the rubber spacers out of the way so the fins can drop into their recesses.
When reinstalling the logic board, insert the left side first to reposition the HMDI and SDXC ports.
Use your fingers to slightly compress the HDMI port to fit it into its recess. Otherwise, the logic board won't sit correctly.
Turn the logic board upside-down so that the heat sink screws face upwards.
Use a T5 Torx driver to remove the four 3.9 mm screws securing the heat sink to the logic board.
Attrezzo utilizzato in questo passaggio:iFixit Thermal Paste$21.99
Use your fingers to lift the logic board up and off of the heat sink.
Remove the heat sink.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2021 Answers community for help.
Un commento
Guys, it's a disassembly guide - not a heat sink replacement guide.
Why you can't just make a full guide without any addition links to other guides?
I found only how to remove thermal paste (in the guide calls "how to apply thermal past")
1/10 for your guides just because of good photos.
