Salta al contenuto principale
HP ProBook 640 G2 Battery Replacement
Cosa ti serve
  1. HP ProBook 640 G2 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop so the bottom is facing up.
    • Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
    • Use a Torx T9 screwdriver to remove the single 6 mm screw.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP ProBook 640 G2 Battery Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to carefully pry the bottom case.
    • Insert the end of the opening tool into the seam between the bottom and top case and slide it around the perimeter to release the clips.
    • Remove the bottom cover.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP ProBook 640 G2 Battery Replacement: passo 3, immagine 1 di 3 HP ProBook 640 G2 Battery Replacement: passo 3, immagine 2 di 3 HP ProBook 640 G2 Battery Replacement: passo 3, immagine 3 di 3
    • Use a JIS J1 screwdriver to remove the seven 6 mm screws securing the battery.
    • Lift the battery from the bottom edge and slide it out of the socket on the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Note - Be sure to dispose of your old battery responsibly! Check out iFixit's Guide on Recycling E-waste.
For optimal performance, calibrate your newly installed battery after completing this guide.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 21
Ultimi 30 giorni: 64
Tutti i Tempi: 300
