Salta al contenuto principale
Google Pixel Watch 4 Screen Replacement
Cosa ti serve
  1. Google Pixel Watch 4 Screen Replacement, Prepare your watch for disassembly: passo 1, immagine 1 di 3 Google Pixel Watch 4 Screen Replacement, Prepare your watch for disassembly: passo 1, immagine 2 di 3 Google Pixel Watch 4 Screen Replacement, Prepare your watch for disassembly: passo 1, immagine 3 di 3
    • Before starting your repair:
    • Remove your watch from the charger.
    • Press and hold the crown button, then tap Power off to shut down your watch.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel Watch 4 Screen Replacement, Remove the watch bands: passo 2, immagine 1 di 3 Google Pixel Watch 4 Screen Replacement, Remove the watch bands: passo 2, immagine 2 di 3 Google Pixel Watch 4 Screen Replacement, Remove the watch bands: passo 2, immagine 3 di 3
    • Remove each watch band by depressing the release button and sliding the band out of its groove.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel Watch 4 Screen Replacement: passo 3, immagine 1 di 1
    • Throughout the rest of your repair, consider placing your watch on something soft like a clean cloth to help stabilize it and prevent scratches to the front glass.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel Watch 4 Screen Replacement, Remove the back sensor glass screws: passo 4, immagine 1 di 3 Google Pixel Watch 4 Screen Replacement, Remove the back sensor glass screws: passo 4, immagine 2 di 3 Google Pixel Watch 4 Screen Replacement, Remove the back sensor glass screws: passo 4, immagine 3 di 3
    • Use a Torx Plus 2IP screwdriver to remove the 3.0 mm‑long screw from both watch band grooves (two screws total).
    • Both screws have a tiny O‑ring. If they don't lift away with the screw, use a pair of tweezers to carefully remove them from the band groove and set them aside. These O-rings are required to maintain waterproofing.
    • Handle these O-rings carefully. Avoid pinching or slicing them with your tool.
    • During reassembly:
    • Make sure the O‑rings are on the screws before installing them.
    • Push down firmly on the back glass while installing the screws to make sure the glass gets properly seated.
    • If there's a gap between the back glass and frame, remove the screws and reinstall them.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel Watch 4 Screen Replacement, Separate the back sensor glass: passo 5, immagine 1 di 2 Google Pixel Watch 4 Screen Replacement, Separate the back sensor glass: passo 5, immagine 2 di 2
    • Insert the point of a spudger (or a clean fingernail) into the seam between the back sensor glass and frame and pry up until the cover detaches.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: passo 6, immagine 1 di 3 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: passo 6, immagine 2 di 3 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: passo 6, immagine 3 di 3
    • Gently lift the back glass and flip it over the side of the watch opposite the crown.
    • Be careful not to strain the cable connecting the back sensor glass.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel Watch 4 Screen Replacement, Remove the vibration motor screws: passo 7, immagine 1 di 2 Google Pixel Watch 4 Screen Replacement, Remove the vibration motor screws: passo 7, immagine 2 di 2
    • Optionally, you can disconnect the back glass to give you more room to work—though you can complete the repair just fine with it still connected.
    • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the vibration motor.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel Watch 4 Screen Replacement, Remove the vibration motor: passo 8, immagine 1 di 2 Google Pixel Watch 4 Screen Replacement, Remove the vibration motor: passo 8, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: passo 9, immagine 1 di 3 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: passo 9, immagine 2 di 3 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: passo 9, immagine 3 di 3
    • Gently flip the back sensor glass over the crown-side of the watch.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel Watch 4 Screen Replacement, Disconnect the battery: passo 10, immagine 1 di 2 Google Pixel Watch 4 Screen Replacement, Disconnect the battery: passo 10, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    • During reassembly, use the point of a spudger to press down and reconnect the press connector.
    • This can be tricky, and may take a few tries.
    • If you're having trouble, loosen the two battery screws and reposition the connector. Once connected, re-tighten the battery screws.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel Watch 4 Screen Replacement, Remove the battery screws: passo 11, immagine 1 di 2 Google Pixel Watch 4 Screen Replacement, Remove the battery screws: passo 11, immagine 2 di 2
    • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the battery.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel Watch 4 Screen Replacement, Remove the battery: passo 12, immagine 1 di 3 Google Pixel Watch 4 Screen Replacement, Remove the battery: passo 12, immagine 2 di 3 Google Pixel Watch 4 Screen Replacement, Remove the battery: passo 12, immagine 3 di 3
    • Remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket screws: passo 13, immagine 1 di 2 Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket screws: passo 13, immagine 2 di 2
    • Use a Torx Plus 1IP screwdriver to remove the two 2.0 mm‑long screws seucuring the screen cable bracket.
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket: passo 14, immagine 1 di 3 Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket: passo 14, immagine 2 di 3 Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket: passo 14, immagine 3 di 3
    • Use tweezers to flip the bracket up and slowly peel it off the connector, being careful not to damage the tape.
    • During reassembly, apply the tape to the outer press connector before flipping the bracket over and into place.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel Watch 4 Screen Replacement, Disconnect the screen cable: passo 15, immagine 1 di 3 Google Pixel Watch 4 Screen Replacement, Disconnect the screen cable: passo 15, immagine 2 di 3 Google Pixel Watch 4 Screen Replacement, Disconnect the screen cable: passo 15, immagine 3 di 3
    • Insert the flat end of a spudger into the gap in the two screen cable press connectors.
    • Twist the spudger to disconnect the cables.
    • During reassembly, line the press connectors up and pinch them together to connect them.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: passo 16, immagine 1 di 2 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: passo 16, immagine 2 di 2
    • Gently flip the back glass over the side of the watch opposite the crown.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel Watch 4 Screen Replacement, Remove the screen screws: passo 17, immagine 1 di 2 Google Pixel Watch 4 Screen Replacement, Remove the screen screws: passo 17, immagine 2 di 2
    • Remove the four screws securing the display:
    • One 5.1 mm‑long Torx Plus 2IP screw
    • Two 3.3 mm‑long Torx Plus 2IP screws
    • One 4.2 mm‑long Torx Plus 5IP standoff screw
    • During reassembly, push down on the frame while installing the screws to make sure they're threading into their holes on the display.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel Watch 4 Screen Replacement, Move the back sensor glass and flip over the watch: passo 18, immagine 1 di 3 Google Pixel Watch 4 Screen Replacement, Move the back sensor glass and flip over the watch: passo 18, immagine 2 di 3 Google Pixel Watch 4 Screen Replacement, Move the back sensor glass and flip over the watch: passo 18, immagine 3 di 3
    • Flip the back sensor glass into place and flip your watch over so the screen faces up.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel Watch 4 Screen Replacement, Separate the screen: passo 19, immagine 1 di 2 Google Pixel Watch 4 Screen Replacement, Separate the screen: passo 19, immagine 2 di 2
    • Insert the flat end of a spudger in the seam between the screen and frame and twist the spudger to separate the screen.
    • The display seals with an O-ring and might "pop" up once released.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel Watch 4 Screen Replacement, Remove the screen: passo 20, immagine 1 di 3 Google Pixel Watch 4 Screen Replacement, Remove the screen: passo 20, immagine 2 di 3 Google Pixel Watch 4 Screen Replacement, Remove the screen: passo 20, immagine 3 di 3
    • Lift the display up and carefully guide the screen cable out of its cutout to remove the screen.
    • During reassembly, feed the screen cable through its cutout until you can grip it with your fingers on the opposite side, then gently pull it through.
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel Watch 4 Screen Replacement, O-ring installation: passo 21, immagine 1 di 3 Google Pixel Watch 4 Screen Replacement, O-ring installation: passo 21, immagine 2 di 3 Google Pixel Watch 4 Screen Replacement, O-ring installation: passo 21, immagine 3 di 3
    • If you plan to reuse the existing O-ring, be gentle when handling it—especially with sharp tweezers. Even a small indent may compromise the watch's water and dust resistance.
    • Use a pair of tweezers to remove the screen O‑ring—it will either be stuck to the frame or the underside of the screen.
    • If the O‑ring's groove is dirty or has gunk built up, apply a few drops of high‑concentration (>90%) isopropyl alcohol to a cotton swab and wipe it clean.
    • Avoid applying isopropyl alcohol to the magnetic strip on the side opposite the crown.
    • Place the new O‑ring loosely onto its lip on the frame.
    • Optionally, coat the O-ring in a small amount of O-ring-specific grease during installation.
    • Use your fingers to hold the O-ring in place and use a spudger to slide the opposite side up and over the lip until it seats in its groove.
    • Make sure the entire O‑ring is properly seated in its groove before continuing reassembly.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Once you've completed your repair, your watch may not power back on until connected to power.
Altre 12 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
191.211 Reputazione
1.204 guide realizzate
9Commenti sulla guida
Any idea when the replacement screens will be available to purchase?
nathan - Rispondi Condividi
When will the parts be available?
JR1 - Rispondi Condividi
I've reassembled after a screen replacement and the watch wont boot. Is this most likely a battery connector problem?
Adam D - Rispondi Condividi
I have the same issue. The watch wont boot after reassembling
Yurii Abramkin - Rispondi Condividi
I had the same issue. The Solution was to leave it on the charger for 15-20 Minutes. On the charger it showed the Google-Logo and then 0%, after a few minutes it showed the real 100% again and the watch worked without anny issues.
Andi “DasGorke” - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 43
Ultimi 7 giorni: 286
Ultimi 30 giorni: 1,352
Tutti i Tempi: 12,902
