Salta al contenuto principale
Google Pixel Watch 4 Back Sensor Glass Replacement
Cosa ti serve
  1. Google Pixel Watch 4 Back Sensor Glass Replacement, Prepare your watch for disassembly: passo 1, immagine 1 di 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Prepare your watch for disassembly: passo 1, immagine 2 di 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Prepare your watch for disassembly: passo 1, immagine 3 di 3
    • Before starting your repair:
    • Remove your watch from the charger.
    • Press and hold the crown button, then tap Power off to shut down your watch.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the watch bands: passo 2, immagine 1 di 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the watch bands: passo 2, immagine 2 di 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the watch bands: passo 2, immagine 3 di 3
    • Remove each watch band by depressing the release button and sliding the band out of its groove.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel Watch 4 Back Sensor Glass Replacement: passo 3, immagine 1 di 1
    • Throughout the rest of your repair, consider placing your watch on something soft like a clean cloth to help stabilize it and prevent scratches to the front glass.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass screws: passo 4, immagine 1 di 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass screws: passo 4, immagine 2 di 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass screws: passo 4, immagine 3 di 3
    • Use a Torx Plus 2IP screwdriver to remove the 3.0 mm‑long screw from both watch band grooves (two screws total).
    • Both screws have a tiny O‑ring. If they don't lift away with the screw, use a pair of tweezers to carefully remove them from the band groove and set them aside. These O-rings are required to maintain waterproofing.
    • Handle these O-rings carefully. Avoid pinching or slicing them with your tool.
    • During reassembly:
    • Make sure the O‑rings are on the screws before installing them.
    • Push down firmly on the back glass while installing the screws to make sure the glass gets properly seated.
    • If there's a gap between the back glass and frame, remove the screws and reinstall them.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel Watch 4 Back Sensor Glass Replacement, Separate the back sensor glass: passo 5, immagine 1 di 2 Google Pixel Watch 4 Back Sensor Glass Replacement, Separate the back sensor glass: passo 5, immagine 2 di 2
    • Insert the point of a spudger (or a clean fingernail) into the seam between the back sensor glass and frame and pry up until the cover detaches.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel Watch 4 Back Sensor Glass Replacement, Reposition the back sensor glass: passo 6, immagine 1 di 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Reposition the back sensor glass: passo 6, immagine 2 di 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Reposition the back sensor glass: passo 6, immagine 3 di 3
    • Gently lift the back glass and flip it over the side of the watch opposite the crown.
    • Be careful not to strain the cable connecting the back sensor glass.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel Watch 4 Back Sensor Glass Replacement, Disconnect the back sensor glass: passo 7, immagine 1 di 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Disconnect the back sensor glass: passo 7, immagine 2 di 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Disconnect the back sensor glass: passo 7, immagine 3 di 3
    • Use a spudger to lift the small, hinged locking‑flap on the back sensor glass ZIF connector.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass: passo 8, immagine 1 di 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass: passo 8, immagine 2 di 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass: passo 8, immagine 3 di 3
    • Gently slide the cable out of its socket and remove the back sensor glass.
    • During reassembly, make sure the locking flap is lifted before sliding the cable fully into its connector—it should snap into place.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
191.306 Reputazione
1.204 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 29
Ultimi 30 giorni: 127
Tutti i Tempi: 1,196
