Introduzione
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a broken or cracked rear cover on your Google Pixel 9 Pro XL.
You'll need replacement rear cover adhesive to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the rear cover adhesive.
Cosa ti serve
Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
Insert the tip of an opening pick in the gap.
Slide your opening pick along the bottom edge to separate the adhesive securing it.
Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
Use the point of a spudger to pry up and disconnect the rear cover press connector.
To reassemble your device, follow this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Altre 9 persone hanno completato questa guida.
5Commenti sulla guida
User Torx Plus 3IP screwdriver? I don't find the screwdriver anywhere . Can I use one screw from this toolkit? If so, which one? - Essential Electronics Toolkit
Does the rear cover come with glue? Or I have to buy the separately?
ifixit's instructions that show a suction cup to remove a screen or a glass back always assume your glass is intact. I would assume most often it is shattered so forget using a suction cup. I used some thick shipping tape to cover the broken glass which gives the suction cup a chance to hold.
