Salta al contenuto principale
Google Pixel 9 Pro Fold Outer Front Camera Replacement
Cosa ti serve
  1. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Prepare your phone for disassembly: passo 1, immagine 1 di 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • Insert an opening pick into the gap.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Separate the adhesive: passo 3, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Separate the adhesive: passo 3, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Separate the adhesive: passo 3, immagine 3 di 3
    • During the next four steps, don't insert your opening pick deeper than 3 mm to prevent damaging internal components.
    • Optionally, you can measure and mark your opening pick 3 mm from the tip to help you visualize the length.
    • Slide the opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 4, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 4, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 4, immagine 3 di 3
    • Slide the pick around the top right corner and stop before the front camera.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 5, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 5, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 5, immagine 3 di 3
    • Pull the opening pick out so only the tip is under the screen.
    • Slide the opening pick across the top edge of the screen until you're past the front camera.
    • Push your pick to its original depth before continuing.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 6, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 6, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 6, immagine 3 di 3
    • Slide the opening pick around the top left corner and stop about two‑thirds down the left edge of the screen.
    • Don't slide the pick any farther, or you risk damaging the display cable.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 7, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 7, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 7, immagine 3 di 3
    • Pull the opening pick out to a 2 mm depth and rotate the pick around the bottom left corner to separate the remaining adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 8, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 8, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 8, immagine 3 di 3
    • Don't fully remove the screen yet, as it's still connected to the phone by a cable.
    • At this point, the screen should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the right edge of the screen and swing it over the left edge of the phone, like opening a book.
    • Prop up the screen with your suction handle or a clean, sturdy object.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the display cable bracket screw: passo 9, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the display cable bracket screw: passo 9, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    FixMat
    $31.41
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 2.2 mm‑long screw securing the display cable bracket.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 10, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 10, immagine 2 di 2
    • Conductive tape secures the display cable bracket to the frame.
    • Use a spudger, or your fingers, to lift the display cable bracket enough to access the press connector underneath.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Disconnect the display cable: passo 11, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Disconnect the display cable: passo 11, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the display cable press connector.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the screen: passo 12, immagine 1 di 1
    • Lift the screen off the frame and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the battery bracket screw: passo 13, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the battery bracket screw: passo 13, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the 2.0 mm‑long screw securing the battery bracket.
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Disconnect the battery: passo 14, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Disconnect the battery: passo 14, immagine 2 di 2
    • Conductive tape secures the battery connector bracket to the lower board.
    • Use tweezers, or your fingers, to move the battery bracket out of the way of the battery press connector.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 15, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 15, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the rubber block: passo 16, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the rubber block: passo 16, immagine 2 di 2
    • Use tweezers, or your fingers, to remove the rubber block covering a screw on the top board.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top interconnect cable bracket screws: passo 17, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top interconnect cable bracket screws: passo 17, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the two 2.2 mm‑long screws securing the top interconnect cable bracket.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top interconnect cable bracket: passo 18, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top interconnect cable bracket: passo 18, immagine 2 di 2
    • Use tweezers, or your fingers, to remove the top interconnect cable bracket.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Disconnect the top interconnect cable: passo 19, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Disconnect the top interconnect cable: passo 19, immagine 2 di 2
    • Insert the point of a spudger under the top right corner of the top interconnect cable press connector, near the golden marker.
    • Pry up and disconnect the top interconnect cable press connector.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top board screw: passo 20, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top board screw: passo 20, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the 2.2 mm‑long screw securing the top board.
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top board: passo 21, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top board: passo 21, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top board: passo 21, immagine 3 di 3
    • Be careful not to puncture or deform the battery during this step.
    • Insert the flat end of a spudger under the bottom edge of the top board.
    • Twist the spudger to lift the top board and unclip it from the frame.
    • Remove the top board.
    Chiedi a FixBot
    Aggiungi Commento
  22. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the outer front camera: passo 22, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the outer front camera: passo 22, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the outer front camera: passo 22, immagine 3 di 3
    • Don't press down heavily on the top board during this step to prevent bending the metal springs and connector pins.
    • Insert the point of a spudger under the top right corner of the front camera press connector, next to the golden marker on the top board.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the outer front camera.
    Chiedi a FixBot
    Aggiungi Commento
  23. Google Pixel 9 Pro Fold Outer Front Camera Replacement, End of disassembly: passo 23, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    Chiedi a FixBot
    Aggiungi Commento
  24. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reconnect the outer front camera: passo 24, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reconnect the outer front camera: passo 24, immagine 2 di 2
    • Use your fingers to pinch the outer front camera press connector into its socket on the top board to reconnect it.
    Chiedi a FixBot
    Aggiungi Commento
  25. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the top board: passo 25, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the top board: passo 25, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the top board: passo 25, immagine 3 di 3
    • Press the top edge of the top board against the frame at a downward angle to engage its metal spring.
    • Press the board flat to the frame, making sure the screw holes are aligned.
    Chiedi a FixBot
    Aggiungi Commento
  26. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 26, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 26, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the 2.2 mm‑long screw securing the top board.
    Chiedi a FixBot
    Aggiungi Commento
  27. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reconnect the top interconnect cable: passo 27, immagine 1 di 1
    • Reconnect the top interconnect cable press connector.
    Chiedi a FixBot
    Aggiungi Commento
  28. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the top interconnect cable bracket: passo 28, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the top interconnect cable bracket: passo 28, immagine 2 di 2
    • Place the top interconnect cable bracket on the top board and align its screw holes.
    Chiedi a FixBot
    Aggiungi Commento
  29. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 29, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 29, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the two 2.2 mm‑long screws securing the top interconnect cable bracket.
    Chiedi a FixBot
    Aggiungi Commento
  30. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the rubber block: passo 30, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the rubber block: passo 30, immagine 2 di 2
    • Place the rubber block over its spot on the top board and press it down.
    Chiedi a FixBot
    Aggiungi Commento
  31. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reconnect the flip battery: passo 31, immagine 1 di 1
    • Reconnect the flip battery press connector.
    Chiedi a FixBot
    Aggiungi Commento
  32. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the flip battery bracket: passo 32, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the flip battery bracket: passo 32, immagine 2 di 2
    • Lay the flip battery bracket over the press connector and align the screw holes.
    Chiedi a FixBot
    Aggiungi Commento
  33. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 33, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 33, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the 2.0 mm‑long screw securing the battery bracket.
    Chiedi a FixBot
    Aggiungi Commento
  34. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the old adhesive: passo 34, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the old adhesive: passo 34, immagine 2 di 2
    • If your outer screen adhesive at the bottom left corner isn't sticky anymore, follow the next four steps to replace it. Otherwise, skip the next four steps.
    • Use a spudger, or your fingers, to remove the old bottom left outer screen adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
    Chiedi a FixBot
    Aggiungi Commento
  35. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Compare your new adhesive: passo 35, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Compare your new adhesive: passo 35, immagine 2 di 2
    • Before removing any liners, check if the bottom left outer screen adhesive matches the frame.
    • The clear liner should face the frame.
    Chiedi a FixBot
    Aggiungi Commento
  36. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Apply the new adhesive: passo 36, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Apply the new adhesive: passo 36, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Apply the new adhesive: passo 36, immagine 3 di 3
    • Peel the bottom left outer screen adhesive off its clear liner to expose the adhesive.
    • Put the adhesive into place on the frame.
    Chiedi a FixBot
    Aggiungi Commento
  37. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 37, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 37, immagine 2 di 2
    • Use the flat end of a spudger to press along the adhesive strip to adhere it to the frame.
    Chiedi a FixBot
    Aggiungi Commento
  38. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Apply the new adhesive: passo 38, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Apply the new adhesive: passo 38, immagine 2 di 2
    • Before removing any liners, check if the perimeter outer screen adhesive matches the frame.
    Chiedi a FixBot
    Aggiungi Commento
  39. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 39, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 39, immagine 2 di 2
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded.
    Chiedi a FixBot
    Aggiungi Commento
  40. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 40, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 40, immagine 2 di 2
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
    Chiedi a FixBot
    Aggiungi Commento
  41. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 41, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 41, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 41, immagine 3 di 3
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
    Chiedi a FixBot
    Aggiungi Commento
  42. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 42, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 42, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 42, immagine 3 di 3
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  43. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 43, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 43, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 43, immagine 3 di 3
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
    Chiedi a FixBot
    Aggiungi Commento
  44. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 44, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 44, immagine 2 di 2
    • Use the tip of a spudger to pry up the segmented tab on the bottom left corner of the large blue liner.
    Chiedi a FixBot
    Aggiungi Commento
  45. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 45, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 45, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 45, immagine 3 di 3
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it to the frame.
    Chiedi a FixBot
    Aggiungi Commento
  46. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reconnect the outer screen: passo 46, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reconnect the outer screen: passo 46, immagine 2 di 2
    • Support the screen with your hand or prop it up on something sturdy.
    • Reconnect the outer screen cable press connector.
    Chiedi a FixBot
    Aggiungi Commento
  47. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the outer screen cable bracket: passo 47, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the outer screen cable bracket: passo 47, immagine 2 di 2
    • Reinsert the outer screen cable bracket clip under the frame and align its screw hole.
    Chiedi a FixBot
    Aggiungi Commento
  48. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 48, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 48, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the 2.2 mm‑long screw securing the display cable bracket.
    Chiedi a FixBot
    Aggiungi Commento
  49. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Expose the adhesive: passo 49, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Expose the adhesive: passo 49, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Expose the adhesive: passo 49, immagine 3 di 3
    • Remove the blue liner from the bottom left outer screen adhesive strip.
    • While holding the screen above the frame, separate one of the secondary liner's pull tabs at the bottom left corner.
    Chiedi a FixBot
    Aggiungi Commento
  50. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 50, immagine 1 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 50, immagine 2 di 3 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 50, immagine 3 di 3
    • Still holding the screen, peel off the secondary liner to expose the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  51. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Secure the outer screen: passo 51, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Secure the outer screen: passo 51, immagine 2 di 2
    • Align the outer screen over the frame and press it into place.
    Chiedi a FixBot
    Aggiungi Commento
  52. Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 52, immagine 1 di 2 Google Pixel 9 Pro Fold Outer Front Camera Replacement: passo 52, immagine 2 di 2
    • Press along the perimeter of the outer screen to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Congratulations on completing your repair!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
Alex Diaz-Kokaisl
Membro da: 01/16/22
239.231 Reputazione
1.171 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
25.946 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 24
Tutti i Tempi: 450
