Salta al contenuto principale
Google Pixel 9 Pro Fold Loudspeaker Replacement
Cosa ti serve
  1. Google Pixel 9 Pro Fold Loudspeaker Replacement, Prepare your phone for disassembly: passo 1, immagine 1 di 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Google Pixel 9 Pro Fold Loudspeaker Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Apply a suction cup to the back cover, as close to the center of the bottom edge as possible.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert an opening pick into the gap.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back cover.
  3. Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the back cover adhesive: passo 3, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the back cover adhesive: passo 3, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the back cover adhesive: passo 3, immagine 3 di 3
    • During the next two steps, don't insert your opening pick deeper than 3 mm to prevent damaging the metal springs around the frame.
    • Optionally, you can measure and mark your opening pick at 3 mm to help you visualize the length.
    • Remove the suction handle from the back cover.
    • Slide the opening pick around the bottom left corner and up the left edge of the back cover to separate the adhesive.
  4. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 4, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 4, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 4, immagine 3 di 3
    • Continue sliding the pick around the top left corner and across the top edge of the back cover.
  5. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 5, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 5, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 5, immagine 3 di 3
    • The adhesive along the right edge of the back cover is thicker than the rest. You'll need to insert your opening pick at a minimum of 4 mm to separate the adhesive.
    • Slide your pick down the right edge and around the bottom right corner to separate the remaining adhesive.
  6. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 6, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 6, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 6, immagine 3 di 3
    • Don't fully remove the back cover yet, as it's still connected to the phone by a cable.
    • At this point, the back cover should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the bottom edge of the back cover and swing it over the top edge of the phone.
    • Prop up the back cover with your suction handle or a clean, sturdy object—making sure that the cable isn't strained.
  7. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the top bracket screw: passo 7, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the top bracket screw: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    FixMat
    $36.95
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the top bracket.
  8. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the top bracket: passo 8, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the top bracket: passo 8, immagine 2 di 2
    • Use tweezers, or your fingers, to pull the top bracket towards the top of the phone to release it from its clip.
    • Remove the top bracket.
  9. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the back cover cable: passo 9, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the back cover cable: passo 9, immagine 2 di 2
    • Insert the tip of your spudger under the bottom edge of the back cover cable press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the back cover cable.
  10. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the back cover: passo 10, immagine 1 di 1
    • Lift the back cover off the frame and remove it.
  11. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the base battery bracket screws: passo 11, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the base battery bracket screws: passo 11, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the base battery bracket.
  12. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the base battery bracket: passo 12, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the base battery bracket: passo 12, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the base battery bracket: passo 12, immagine 3 di 3
    • Use tweezers, or your fingers, to pull the base battery bracket toward the bottom of the phone to release it from its clip.
    • Remove the base battery bracket.
  13. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the base battery: passo 13, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the base battery: passo 13, immagine 2 di 2
    • Insert the tip of your spudger under the bottom left corner of the base battery press connector, near the gold marker.
    • Pry up and disconnect the base battery.
  14. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the USB-C port board cable: passo 14, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the USB-C port board cable: passo 14, immagine 2 di 2
    • Use a spudger to pry up and disconnect the USB-C port board cable press connector.
  15. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the vibrator bracket screws: passo 15, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the vibrator bracket screws: passo 15, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the vibrator bracket.
  16. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the vibrator bracket: passo 16, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the vibrator bracket: passo 16, immagine 2 di 2
    • Use tweezers, or your fingers, to lift the vibrator bracket off the frame and remove it.
  17. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the antenna cable: passo 17, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the antenna cable: passo 17, immagine 2 di 2
    • Slide one arm of a pair of angled tweezers under the metal neck of the black antenna cable's connector head on the USB‑C board.
    • Lift straight up to disconnect the cable.
  18. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera bracket screws: passo 18, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera bracket screws: passo 18, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the two 2.6 mm‑long screws securing the inner front camera bracket.
  19. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera bracket: passo 19, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera bracket: passo 19, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera bracket: passo 19, immagine 3 di 3
    • Use tweezers, or your fingers, to lift the inner front camera bracket up and toward the left edge of the phone to release its clips.
    • Remove the inner front camera bracket.
  20. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the inner front camera: passo 20, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the inner front camera: passo 20, immagine 2 di 2
    • Use a spudger to pry up and disconnect the inner front camera press connector.
  21. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera: passo 21, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera: passo 21, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera: passo 21, immagine 3 di 3
    • Use the point of a spudger to pry up the inner front camera and separate the adhesive securing it to the frame.
    • Remove the inner front camera.
  22. Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the ultra wideband antenna: passo 22, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the ultra wideband antenna: passo 22, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the ultra wideband antenna: passo 22, immagine 3 di 3
    • Slide the flat end of a spudger under the ultra wideband antenna to separate the adhesive foam securing it to the frame.
    • Use tweezers, or your fingers, to lift the antenna off the frame to separate any remaining adhesive.
  23. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the ultra wideband bracket screws: passo 23, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the ultra wideband bracket screws: passo 23, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the ultra wideband bracket.
  24. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the ultra wideband bracket: passo 24, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the ultra wideband bracket: passo 24, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the ultra wideband bracket: passo 24, immagine 3 di 3
    • While holding the ultra wideband antenna out of the way, pull the bracket toward the bottom of the phone to release its clips.
    • Remove the ultra wideband bracket.
  25. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the bottom interconnect cable bracket screw: passo 25, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the bottom interconnect cable bracket screw: passo 25, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the interconnect cable bracket.
  26. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the bottom interconnect cable bracket: passo 26, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the bottom interconnect cable bracket: passo 26, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the bottom interconnect cable bracket: passo 26, immagine 3 di 3
    • Use tweezers, or your fingers, to pull the bracket toward the right edge of the phone to release its clip.
    • Remove the bottom interconnect cable bracket.
  27. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner display cable bracket screw: passo 27, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner display cable bracket screw: passo 27, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the inner display cable bracket.
  28. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner display cable bracket: passo 28, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner display cable bracket: passo 28, immagine 2 di 2
    • Use tweezers, or your fingers, to pull the inner display cable bracket towards the left edge of the phone to release it from its clip.
    • Remove the inner display cable bracket.
  29. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the inner display cable: passo 29, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the inner display cable: passo 29, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the inner display cable: passo 29, immagine 3 di 3
    • Insert the point of a spudger under the bottom left corner of the inner display press connector, next to the gold marker on the logic board.
    • Pry up and disconnect the inner display cable.
  30. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 30, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 30, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 30, immagine 3 di 3
    • Repeat the previous step to disconnect the top and bottom interconnect cable press connectors, making sure to only pry next to the gold markers.
  31. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the graphite sheet: passo 31, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the graphite sheet: passo 31, immagine 2 di 2
    • Peel the graphite sheet off the bottom speaker to separate the adhesive securing it.
  32. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 32, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 32, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 32, immagine 3 di 3
    • Continue peeling the graphite sheet off the logic board to separate the remaining adhesive.
  33. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the side buttons: passo 33, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the side buttons: passo 33, immagine 2 di 2
    • Use tweezers, or your fingers, to peel off the yellow tape on the side button cable ZIF connector.
    • Set the tape aside. You'll need it during reassembly.
  34. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 34, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 34, immagine 2 di 2
    • Use the point of a spudger, or your fingernail, to lift the locking tab on the side button cable ZIF connector.
  35. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 35, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 35, immagine 2 di 2
    • Use angled tweezers to pull the side button cable straight out of its slot.
    • Take care not to puncture the battery—it can leak dangerous chemicals and/or catch fire.
  36. Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the 5G mmWave antenna: passo 36, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the 5G mmWave antenna: passo 36, immagine 2 di 2
    • A thermal pad lightly adheres the 5G mmWave antenna to the frame.
    • Use the tip of a spudger to pry up the 5G mmWave antenna from the frame and separate it from the thermal pad.
  37. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the logic board screws: passo 37, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the logic board screws: passo 37, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the three screws securing the logic board:
    • One 2.2 mm‑long screw
    • Two 2.6 mm‑long screws
  38. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the logic board: passo 38, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the logic board: passo 38, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the logic board: passo 38, immagine 3 di 3
    • Insert the flat end of a spudger under the top left corner of the logic board, next to the inner front camera cutout.
    • You might feel some resistance since the logic board is bonded to the frame by thermal paste.
    • Pry up the logic board enough so you can grip the top edge with your fingers.
  39. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 39, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 39, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 39, immagine 3 di 3
    • Lift the top of the logic board out of the frame and remove it.
    • Lay down the logic board upside down on a clean surface.
  40. Google Pixel 9 Pro Fold Loudspeaker Replacement, Clean the thermal paste: passo 40, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Clean the thermal paste: passo 40, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Clean the thermal paste: passo 40, immagine 3 di 3
    • Use the flat end of a spudger to scrape away large pieces of old thermal paste from the frame.
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to any remaining thermal paste residue.
    • Wipe away the residue using a coffee filter or lint-free cloth.
  41. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 41, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 41, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 41, immagine 3 di 3
    • Don't press down heavily on the logic board while cleaning it to prevent bending the metal springs or smudging the rear camera assembly.
    • Repeat the thermal paste cleaning procedure for the bottom of the logic board.
  42. Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the conductive fabric: passo 42, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the conductive fabric: passo 42, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the conductive fabric: passo 42, immagine 3 di 3
    • Use tweezers, or your fingers, to peel the section of conductive fabric connecting the loudspeaker to the frame.
  43. Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the cable adhesive: passo 43, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the cable adhesive: passo 43, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the cable adhesive: passo 43, immagine 3 di 3
    • Slide one arm of a pair of angled tweezers under the contact pad connected to the loudspeaker.
    • Lift the contact pad to separate the adhesive securing it to the frame.
  44. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the loudspeaker screw: passo 44, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the loudspeaker screw: passo 44, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the 2.6 mm‑long screw securing the loudspeaker.
  45. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the loudspeaker: passo 45, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the loudspeaker: passo 45, immagine 2 di 2
    • Use the tip of a spudger to pry up the left edge of the loudspeaker to separate the adhesive securing it to the frame.
  46. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 46, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 46, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 46, immagine 3 di 3
    • Use your fingers to lift the top edge of the loudspeaker and pull it out of its recess in the frame.
    • Remove the loudspeaker.
  47. Google Pixel 9 Pro Fold Loudspeaker Replacement, End of disassembly: passo 47, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
  48. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: passo 48, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: passo 48, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: passo 48, immagine 3 di 3
    • The next six steps show how to replace the conductive fabric on the bottom of your loudspeaker and the adhesive on the loudspeaker's cable. Skip these steps if your fabric and adhesive are intact.
    • Use tweezers, or your fingers, to remove the bottom and top conductive fabrics or the loudspeaker cable adhesive if they're not intact.
  49. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the bottom conductive fabric: passo 49, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the bottom conductive fabric: passo 49, immagine 2 di 2
    • Align the bottom loudspeaker conductive fabric on the underside of the loudspeaker.
    • Refer to the second photo for the correct orientation.
  50. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 50, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 50, immagine 2 di 2
    • Remove the conductive fabric from its clear and colored liners and lay it over its spot on the loudspeaker.
  51. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 51, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 51, immagine 2 di 2
    • Use the flat end of a spudger, or your fingers, to press down the conductive fabric and adhere it to the loudspeaker.
  52. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the adhesive: passo 52, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the adhesive: passo 52, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the adhesive: passo 52, immagine 3 di 3
    • Peel the clear liner off the loudspeaker cable adhesive.
    • Align the adhesive over the loudspeaker cable and lay it down, making sure not to cover the hole in the cable.
  53. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 53, immagine 1 di 1
    • Use your fingers to lightly pinch the cable and adhere the adhesive strip.
    • Remove the blue liner from the adhesive strip.
  54. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the loudspeaker: passo 54, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the loudspeaker: passo 54, immagine 2 di 2
    • Align the hole in the loudspeaker cable over its peg on the frame.
    • Press down the cable with the tip of a spudger, or your finger, to adhere it to the frame.
  55. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 55, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 55, immagine 2 di 2
    • While pressing the cable down, reinsert the loudspeaker at an angle into its recess and press it flat to the frame.
  56. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 56, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 56, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 56, immagine 3 di 3
    • While holding the loudspeaker in place, use a Torx Plus 3IP driver to install the 2.6 mm‑long screw securing the loudspeaker.
  57. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the top conductive fabric: passo 57, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the top conductive fabric: passo 57, immagine 2 di 2
    • The next four steps show how to replace the conductive fabric on the top of the loudspeaker. Skip these steps if your fabric is still intact.
    • Peel off the clear liner on the top loudspeaker conductive fabric.
    • Peel off the small colored liner covering the rounded corner of the fabric.
  58. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 58, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 58, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 58, immagine 3 di 3
    • Align the rounded corner of the conductive fabric with the same‑shaped marking on the frame.
    • Lay the fabric down onto the frame and the loudspeaker.
  59. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 59, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 59, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 59, immagine 3 di 3
    • Use the flat end of a spudger, or your fingers, to press down the conductive fabric and adhere it to the frame and loudspeaker.
  60. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 60, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 60, immagine 2 di 2
    • Peel off the large colored liner from the conductive fabric.
  61. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply new thermal paste: passo 61, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply new thermal paste: passo 61, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply new thermal paste: passo 61, immagine 3 di 3
    • Apply small beads of thermal paste (five total) to the motherboard in the same locations as the old thermal paste.
  62. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the logic board: passo 62, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the logic board: passo 62, immagine 2 di 2
    • Place the logic board back into its cutout in the frame, making sure no cables get trapped underneath it.
  63. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 63, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 63, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the three screws securing the logic board:
  64. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the side button cable: passo 64, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the side button cable: passo 64, immagine 2 di 2
    • Use angled tweezers to push the side button cable back into its slot.
  65. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 65, immagine 1 di 1
    • Flip the locking tab down and lightly press on it until it clicks into place.
  66. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 66, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 66, immagine 2 di 2
    • Place the yellow tape over the ZIF connector and its cable.
  67. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new graphite sheet: passo 67, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new graphite sheet: passo 67, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new graphite sheet: passo 67, immagine 3 di 3
    • Peel the clear liner off your replacement graphite sheet to expose the adhesive on the upper half.
    • Align the upper half of the graphite sheet over the logic board and lay it down.
  68. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 68, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 68, immagine 2 di 2
    • Use your finger to press down the upper half of the graphite sheet and secure it to the logic board.
  69. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 69, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 69, immagine 2 di 2
    • Remove the blue liner from the bottom of the graphite sheet to expose the adhesive underneath.
  70. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 70, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 70, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 70, immagine 3 di 3
    • Drag your finger from the middle section of the graphite sheet to the adhesive spot on the loudspeaker to flatten the graphite sheet and adhere it.
  71. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 71, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 71, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 71, immagine 3 di 3
    • Grip the pull tab at the top of the graphite sheet and peel off the remaining liner.
  72. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the right side cables: passo 72, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the right side cables: passo 72, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the right side cables: passo 72, immagine 3 di 3
    • Reconnect the inner display cable and the top and bottom interconnect cable press connectors.
  73. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner display cable bracket: passo 73, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner display cable bracket: passo 73, immagine 2 di 2
    • Reinsert the inner display cable bracket clip under its slot in the logic board and align the screw holes.
  74. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 74, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 74, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the inner display cable bracket.
  75. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the bottom interconnect cable bracket: passo 75, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the bottom interconnect cable bracket: passo 75, immagine 2 di 2
    • Reinsert the bottom interconnect bracket clip under its slot in the frame and align the screw hole.
  76. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 76, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 76, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the interconnect cable bracket.
  77. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the ultra wideband bracket: passo 77, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the ultra wideband bracket: passo 77, immagine 2 di 2
    • While holding the ultra wideband antenna out of the way, reinsert the ultra wideband bracket clip under its slot in the frame and align the screw holes.
  78. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 78, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 78, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the ultra wideband bracket.
  79. Google Pixel 9 Pro Fold Loudspeaker Replacement, Replace the ultra wideband bracket adhesive: passo 79, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Replace the ultra wideband bracket adhesive: passo 79, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Replace the ultra wideband bracket adhesive: passo 79, immagine 3 di 3
    • If the adhesive on your ultra wideband bracket is still sticky, skip this step.
    • Remove the old adhesive and foam on the ultra wideband bracket and under the antenna.
    • Replace the corresponding adhesive and foam to the bracket and the frame.
    • Press the ultra wideband antenna to the frame and re‑adhere it.
  80. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: passo 80, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: passo 80, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: passo 80, immagine 3 di 3
    • Use tweezers, or your fingers, to remove the old adhesive foam from the inner front camera cutout.
    • Use isopropyl alcohol (>90% or greater) and a coffee filter or lint‑free cloth to remove any adhesive residue.
  81. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new adhesive: passo 81, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new adhesive: passo 81, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new adhesive: passo 81, immagine 3 di 3
    • Peel the replacement inner front camera adhesive foam off its clear liner to expose the adhesive underneath.
    • Align the adhesive foam over the cutout in the frame so that the pull tab is facing the bottom of the phone.
    • Place the adhesive in the cutout.
  82. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 82, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 82, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 82, immagine 3 di 3
    • Use the tip of a spudger to press along the edges of the adhesive foam to secure it to the frame.
  83. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 83, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 83, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 83, immagine 3 di 3
    • Use tweezers, or your fingers, to peel off the colored liner and expose the adhesive underneath.
  84. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner front camera: passo 84, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner front camera: passo 84, immagine 2 di 2
    • While holding the inner front camera above its cutout, reconnect its press connector.
    • Lay the inner front camera in its cutout and press down to secure it to the adhesive.
  85. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner front camera bracket: passo 85, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner front camera bracket: passo 85, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner front camera bracket: passo 85, immagine 3 di 3
    • Reinsert the inner front camera bracket clip under its slot in the logic board and align the screw holes.
  86. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 86, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 86, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the two 2.6 mm‑long screws securing the inner front camera bracket.
  87. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the antenna cable: passo 87, immagine 1 di 1
    • Use tweezers to hold the antenna cable's connector in place over its socket and gently press down with your finger or a spudger until the connector snaps into place.
  88. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the vibrator bracket: passo 88, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the vibrator bracket: passo 88, immagine 2 di 2
    • Place the vibrator bracket on the logic board and align its screw holes.
  89. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 89, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 89, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the vibrator bracket.
  90. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the USB-C port board cable: passo 90, immagine 1 di 1
    • Reconnect the USB-C port board cable press connector.
  91. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the base battery: passo 91, immagine 1 di 1
    • Reconnect the base battery press connector.
  92. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the base battery bracket: passo 92, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the base battery bracket: passo 92, immagine 2 di 2
    • Reinsert the base battery bracket clip under its slot in the logic board and align its screw holes.
  93. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 93, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 93, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the base battery bracket.
  94. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: passo 94, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: passo 94, immagine 2 di 2
    • Use a spudger, or your fingers, to remove the old back cover adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
  95. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the back cover liners: passo 95, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the back cover liners: passo 95, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the back cover liners: passo 95, immagine 3 di 3
    • If you're replacing your back cover with a new one, follow the next two steps. Otherwise, skip them.
    • Use tweezers, or your fingers, to remove the three rear camera liners from the inside of your new back cover.
  96. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 96, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 96, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 96, immagine 3 di 3
    • Peel off the remaining clear liners on the outside of the back cover.
  97. Google Pixel 9 Pro Fold Loudspeaker Replacement, Compare your adhesive: passo 97, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Compare your adhesive: passo 97, immagine 2 di 2
    • Before removing any liners, check if the adhesive matches the frame.
    • The clear liner should face the frame.
  98. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new adhesive: passo 98, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new adhesive: passo 98, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new adhesive: passo 98, immagine 3 di 3
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded before continuing.
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
  99. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 99, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 99, immagine 2 di 2
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
  100. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 100, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 100, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 100, immagine 3 di 3
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
  101. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 101, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 101, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 101, immagine 3 di 3
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
  102. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 102, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 102, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 102, immagine 3 di 3
    • Use a spudger to pry up the segmented tab on the bottom right corner of the large blue liner.
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  103. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the back cover cable: passo 103, immagine 1 di 1
    • While holding the back cover or propping it up, reconnect the back cover cable.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  104. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the top bracket: passo 104, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the top bracket: passo 104, immagine 2 di 2
    • Reinsert the top bracket clip under its slot in the logic board and align its screw hole.
  105. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 105, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 105, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the top bracket.
  106. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the secondary liner: passo 106, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the secondary liner: passo 106, immagine 2 di 2
    • Use the tip of a spudger to pry up the segmented tab on the top right corner of the secondary liner.
  107. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 107, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 107, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 107, immagine 3 di 3
    • Peel off the secondary liner to expose the adhesive.
  108. Google Pixel 9 Pro Fold Loudspeaker Replacement, Secure the back cover: passo 108, immagine 1 di 2 Google Pixel 9 Pro Fold Loudspeaker Replacement, Secure the back cover: passo 108, immagine 2 di 2
    • Align the top edge of the back cover with the frame and press down to adhere it.
  109. Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 109, immagine 1 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 109, immagine 2 di 3 Google Pixel 9 Pro Fold Loudspeaker Replacement: passo 109, immagine 3 di 3
    • Press along the perimeter of the back cover to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
Conclusione
Congratulations on completing your repair!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
Alex Diaz-Kokaisl
Membro da: 01/16/22
235.206 Reputazione
1.142 Guide realizzate
iFixit Membro di iFixit
Staff
124 Membri
25.278 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 71
Tutti i Tempi: 968
