Introduzione
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a broken or cracked rear cover (aka back cover) on your Google Pixel 10a.
You'll need replacement rear cover adhesives to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair depends on how accurately the new adhesives are applied and how clean the mating surfaces are.
Cosa ti serve
Unplug all cables and completely power down your Pixel.
Use a hair dryer to heat the entire rear cover until it's hot to the touch.
Apply a suction handle near the center of the rear cover's right edge, as close to the edge as possible.
The rear cover is secured with adhesive around the frame perimeter and near the cameras. Use this picture as a reference while you separate the adhesive.
When separating the left edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and its graphite film.
Slide the opening pick around the entire perimeter to separate the adhesive.
Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
Use your fingers, a spudger, or tweezers to remove the adhesive from the frame perimeter.
If you scrape up a piece big enough to grip with your fingers, you can pull long sections of the adhesive up. Pull slowly and straight in the opposite direction of the adhesive.
Use some high concentration (>90%) isopropyl alcohol and a lint-free cloth (or coffee filter) to remove any adhesive residue.
Inspect the adhesive blocks surrounding the rear cameras. If they're clean and unwrinkled, you can reuse them and skip down three steps.
Use the point of a spudger to scrape up and remove the seven adhesive blocks surrounding the rear cameras.
Peel all the liners from the interior of the rear cover.
Before removing any liners, hold the rear cover adhesive over the phone to figure out how it'll sit on the frame. Use the camera cutout to help with orientation.
Make sure the rear cover camera cutouts are clean. Carefully wipe them with a lint-free cloth if needed.
Make sure the rear camera lenses are clean. Gently wipe them with a lint-free cloth if needed.
Lay the rear cover over the frame.
Firmly press around the perimeter to secure the adhesive.
Congratulations on completing your repair!
