Introduzione
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the outer screen in your Google Pixel 10 Pro Fold.
Cosa ti serve
Unplug all cables from your phone and completely power it down.
Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
Insert an opening pick into the gap.
Slide the opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive.
Strumento utilizzato in questo passaggio:FixMat$31.41
Use a Torx Plus 3IP driver to remove the three screws securing the display cable bracket:
One 1.8 mm‑long screw
Two 2.5 mm‑long screws
Use the point of a spudger to pry up the display bracket and release its clip from the bottom edge of the frame.
Remove the display bracket.
Use the point of a spudger to pry up the display cable press connector.
Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
Use a spudger, or your fingers, to remove the old outer screen adhesive on the frame.
Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
If your new outer screen has a liner covering the front camera cutout, remove it now.
Before removing any liners, check if the outer screen adhesive matches the frame.
Peel away the top half of the new adhesive strip from its clear liner and keep the liner folded before continuing.
Support the screen with your hand or prop it up on something sturdy.
Reconnect the outer screen cable press connector.
Use a Torx Plus 3IP driver to install the three screws securing the display cable bracket:
If your new outer screen comes with pre-installed adhesive, remove the liner to expose its adhesive and skip here.
Use tweezers to grip the pull tab of the secondary liner at the bottom left corner of the phone.
Align the outer screen over the frame and press it into place.
Congratulations on completing your repair!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 10 Pro Fold Answers Community for help.
