Salta al contenuto principale
Beats Studio 2 Wireless Speaker Replacement
Cosa ti serve
    1. Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: passo 1, immagine 1 di 2 Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: passo 1, immagine 2 di 2
      • Insert a spudger between the plastic part of the left headphone and the ear cushion.
      • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
      Chiedi a FixBot
      Aggiungi Commento
    2. Beats Studio 2 Wireless Speaker Replacement: passo 2, immagine 1 di 3 Beats Studio 2 Wireless Speaker Replacement: passo 2, immagine 2 di 3 Beats Studio 2 Wireless Speaker Replacement: passo 2, immagine 3 di 3
      • Pull the rest of the cushion away from the adhesive with your hands.
      Chiedi a FixBot
      Aggiungi Commento
    1. Beats Studio 2 Wireless Speaker Replacement, Speaker: passo 3, immagine 1 di 2 Beats Studio 2 Wireless Speaker Replacement, Speaker: passo 3, immagine 2 di 2
      • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
      • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
      Chiedi a FixBot
      Aggiungi Commento
    2. Beats Studio 2 Wireless Speaker Replacement: passo 4, immagine 1 di 1
      • Gently separate the speaker from the headphones.
      • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
      Chiedi a FixBot
      Aggiungi Commento
    3. Beats Studio 2 Wireless Speaker Replacement: passo 5, immagine 1 di 2 Beats Studio 2 Wireless Speaker Replacement: passo 5, immagine 2 di 2
      • Gently pull the wire with rubber connectors off of the speaker.
      Chiedi a FixBot
      Aggiungi Commento
    4. Beats Studio 2 Wireless Speaker Replacement: passo 6, immagine 1 di 1
      • Use a soldering iron to desolder the two connections.
      • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
      • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
      • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
After soldering the new speaker, reassemble your device by following the steps in reverse order.
Altre 4 persone hanno completato questa guida.
1Commento della guida
I didn't need to replace a speaker but just touch up the solder joints, this was a great guide! Thank you!
William Pryor - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 32
Tutti i Tempi: 1,101
