Salta al contenuto principale
Alienware 17 R3 Battery Replacement
Cosa ti serve
  1. Alienware 17 R3 Battery Replacement, Battery: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
  2. Alienware 17 R3 Battery Replacement: passo 2, immagine 1 di 1
    • Unscrew and remove the two 4mm Phillips #1 screws from the cover.
    • Remember to put the screws in a safe place so you can find them all during re-assembly.
  3. Alienware 17 R3 Battery Replacement: passo 3, immagine 1 di 1
    • Pull up and slide the cover off.
  4. Alienware 17 R3 Battery Replacement: passo 4, immagine 1 di 2 Alienware 17 R3 Battery Replacement: passo 4, immagine 2 di 2
    • Unplug the black wire with the yellow tag to disconnect the battery.
  5. Alienware 17 R3 Battery Replacement: passo 5, immagine 1 di 2 Alienware 17 R3 Battery Replacement: passo 5, immagine 2 di 2
    • Unscrew and remove the four 3mm Phillips #1 screws holding the hard drive in place.
  6. Alienware 17 R3 Battery Replacement: passo 6, immagine 1 di 2 Alienware 17 R3 Battery Replacement: passo 6, immagine 2 di 2
    • Unscrew and remove the four 2mm Phillips #1 screws holding the casing together.
  7. Alienware 17 R3 Battery Replacement: passo 7, immagine 1 di 2 Alienware 17 R3 Battery Replacement: passo 7, immagine 2 di 2
    • Remove the plug from the hard drive.
    • Lift the hard drive out and set aside.
  8. Alienware 17 R3 Battery Replacement: passo 8, immagine 1 di 1
    • Unscrew the one Phillips #1 screw holding down the bottom of the M.2 chip.
    • Pull the M.2 chip straight out of its socket.
  9. Alienware 17 R3 Battery Replacement: passo 9, immagine 1 di 1
    • Unscrew and remove the eight 3mm Phillips #1 screws (located in areas labeled "P").
  10. Alienware 17 R3 Battery Replacement: passo 10, immagine 1 di 1
    • Carefully disconnect the four flex cables.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  11. Alienware 17 R3 Battery Replacement: passo 11, immagine 1 di 1
    • Remove the six 4mm Phillips #1 screws on the side and the two 10mm Phillips #1 screws on the top.
  12. Alienware 17 R3 Battery Replacement: passo 12, immagine 1 di 1
    • Flip over the laptop and open it.
    • Insert the spudger along the edges of the laptop and gently pry upward to lift the keyboard panel.
  13. Alienware 17 R3 Battery Replacement: passo 13, immagine 1 di 1
    • Remove the six 4mm Phillips #1 screws holding the battery in place.
  14. Alienware 17 R3 Battery Replacement: passo 14, immagine 1 di 3 Alienware 17 R3 Battery Replacement: passo 14, immagine 2 di 3 Alienware 17 R3 Battery Replacement: passo 14, immagine 3 di 3
    • Unplug the two sets of wires from the motherboard.
  15. Alienware 17 R3 Battery Replacement: passo 15, immagine 1 di 1
    • Lift out the battery pack.
Conclusione
Altre 20 persone hanno completato questa guida.
UW Tacoma, Team 1-1, Rose Winter 2017 Membro di UW Tacoma, Team 1-1, Rose Winter 2017
UWT-ROSE-W17S1G1
3 Membri
5 Guide realizzate
5 Commenti
Hi ! Nice DIY . Is it possible to disassemble the battery pack and change the cell inside ?
francois tremblay - Replica
Hi, please edit step 10. There a 4th ribbon has to be pulled.
Nevertheless a very good manual.
Steffen Bönisch - Replica
Hi Steffen,
Thanks for the tip! I edited step 10 to correct the mistake.
Arthur Shi -
Very helpful and concise. Worked very well for me. Many Thanks
Ragufta Khan - Replica
After putting everything back together I found my didn't HDD work. It was simply that the other end of the HDD cable had become disconnected.
I'd recommend disconnecting this before removing the HDD housing so it doesn't snag (it's actually shown as disconnected in step 10).
Dom Parrott - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 82
Ultimi 30 Giorni: 310
Tutti i Tempi: 33,314
