Salta al contenuto principale
why! W650SZ LCD Screen Replacement
Cosa ti serve
  1. why! W650SZ LCD Screen Replacement, Battery: passo 1, immagine 1 di 3 why! W650SZ LCD Screen Replacement, Battery: passo 1, immagine 2 di 3 why! W650SZ LCD Screen Replacement, Battery: passo 1, immagine 3 di 3
    • Slide the latch on the right to the unlocked position.
    • Slide the latch on the left to the unlocked position.
    • Remove the battery pack from the slot.
  2. why! W650SZ LCD Screen Replacement, Remove the Bezel: passo 2, immagine 1 di 3 why! W650SZ LCD Screen Replacement, Remove the Bezel: passo 2, immagine 2 di 3 why! W650SZ LCD Screen Replacement, Remove the Bezel: passo 2, immagine 3 di 3
    • Although the photos are shown without a keyboard, it is not necessary to remove the keyboard to replace the screen.
    • Gently insert your fingernail between the display bezel and the LCD.
  3. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): passo 3, immagine 1 di 3 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): passo 3, immagine 2 di 3 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): passo 3, immagine 3 di 3
    • Working your way around the frame, unclip the mounting points of the frame surrounding the LCD screen.
  4. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): passo 4, immagine 1 di 3 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): passo 4, immagine 2 di 3 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): passo 4, immagine 3 di 3
    • Remove the bezel surrounding the LCD.
  5. why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: passo 5, immagine 1 di 3 why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: passo 5, immagine 2 di 3 why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: passo 5, immagine 3 di 3
    • Remove the two upper mounting screws securing the LCD to the lid.
    • Remove the two lower mounting screws.
  6. why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: passo 6, immagine 1 di 3 why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: passo 6, immagine 2 di 3 why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: passo 6, immagine 3 di 3
    • Cover the keyboard with a cloth, then carefully lower the LCD screen onto the keyboard.
  7. why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: passo 7, immagine 1 di 3 why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: passo 7, immagine 2 di 3 why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: passo 7, immagine 3 di 3
    • Note the location of the LCD screen connector.
  8. why! W650SZ LCD Screen Replacement, Remove the Connector Tape: passo 8, immagine 1 di 3 why! W650SZ LCD Screen Replacement, Remove the Connector Tape: passo 8, immagine 2 di 3 why! W650SZ LCD Screen Replacement, Remove the Connector Tape: passo 8, immagine 3 di 3
    • Using the plastic tab, peel back the tape securing the LCD cable the panel connector.
  9. why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: passo 9, immagine 1 di 3 why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: passo 9, immagine 2 di 3 why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: passo 9, immagine 3 di 3
    • Unplug the connector.
    • The LCD screen can now be removed.
Conclusione
Un ringraziamento speciale a questi traduttori:
fr en
100%
Jerry Wheeler ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Felice Suglia
Membro da: 06/15/13
33.562 Reputazione
283 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 27
Tutti i Tempi: 325
