Salta al contenuto principale
nikon s3700 LCD Display Screen Replacement
Sales Cameraparts4you
Sales Cameraparts4you e 3 altri collaboratori
Ultimo aggiornamento il August 22, 2021
20 minuti
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Step by step guide for replacing your damaged LCD Display.
Cosa ti serve
Strumenti
Mostra di più…
  1. nikon s3700 LCD Display Screen Replacement, Removing the Screws: passo 1, immagine 1 di 3 nikon s3700 LCD Display Screen Replacement, Removing the Screws: passo 1, immagine 2 di 3 nikon s3700 LCD Display Screen Replacement, Removing the Screws: passo 1, immagine 3 di 3
    • group screws according to color code.
    • Remove exterior screws
  2. nikon s3700 LCD Display Screen Replacement, Replace LCD: passo 2, immagine 1 di 3 nikon s3700 LCD Display Screen Replacement, Replace LCD: passo 2, immagine 2 di 3 nikon s3700 LCD Display Screen Replacement, Replace LCD: passo 2, immagine 3 di 3
    • Remove Rear casing.
    • With a thin blade, gently lift the top tight hand side of the buttons board releasing a peg from a hole on the midframe below. Whilst doing so, gently push on the top left hand side in order to release the buttons board from a clip. At the same time, the bottom left hand corner wil be released from another clip.
    • Flip over rear buttons board to expose LCD ZIF clamp.
    • Flip open the clamp of the ZIF connector and slide the ribbon cable out. (The connector may have a piece of sticky tape over it. Removing this may well open the connector clamping bar.)
    • The ZIF clamp is very fragile so please use caution when releasing the ZIF clamp. It breaks easily.
    • Remove the LCD.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 16
Tutti i Tempi: 479
