Salta al contenuto principale
iRobot Roomba 551 Side Wheel Replacement
Deborah Newberry
Deborah Newberry e 3 altri collaboratori
Ultimo aggiornamento il December 21, 2020
5 - 15 minuti
Facile
Introduzione
Vai al passo 1
This is an easy way to quickly replace the side wheel of your Roomba. It is slightly more work than the front wheel, which can be found here, but is a straightforward process.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. iRobot Roomba 551 Side Wheel Replacement, Side Brush: passo 1, immagine 1 di 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Side Wheel Replacement: passo 2, immagine 1 di 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Side Wheel Replacement: passo 3, immagine 1 di 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Side Wheel Replacement, Bottom Plate: passo 4, immagine 1 di 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Side Wheel Replacement: passo 5, immagine 1 di 2 iRobot Roomba 551 Side Wheel Replacement: passo 5, immagine 2 di 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Side Wheel Replacement: passo 6, immagine 1 di 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Side Wheel Replacement, Side Wheel: passo 7, immagine 1 di 3 iRobot Roomba 551 Side Wheel Replacement, Side Wheel: passo 7, immagine 2 di 3 iRobot Roomba 551 Side Wheel Replacement, Side Wheel: passo 7, immagine 3 di 3
    • Find the blue wheel at the bottom of the Roomba, and unscrew the three captive screws holding it in place using a Phillips #1 screwdriver.
  8. iRobot Roomba 551 Side Wheel Replacement: passo 8, immagine 1 di 2 iRobot Roomba 551 Side Wheel Replacement: passo 8, immagine 2 di 2
    • Gently lift the wheel to remove.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 13-14, Regan Winter 2014 Membro di Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Membri
19 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,335
