iPod Touch 4th Generation Wi-Fi Antenna Replacement
Introduzione
Vai al passo 1Use this guide to replace the small Wi-Fi antenna located near the top left corner of your iPod Touch.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
With the heat gun set on "low", begin heating the lower portion of the Touch near the home button.
Insert the edge of an opening tool under the steel mid plate near the bottom left corner of the Touch.
Slowly pry upward to separate the plate from the adhesive securing it to the plastic inner case.
If the plate is still attached to the logic board, re-warm the area to loosen the adhesive, then slowly separate the plate from the logic board using the opening tool.
There is a thin, fragile ribbon cable underneath the plate. As you pry the plate up, be very careful not to rip the cable.
While carefully lifting the top edge of the logic board, use the edge of an iPod opening tool to pry the Wi-Fi antenna connector away from the logic board.
Remove the Wi-Fi antenna from your iPod.
Altre 59 persone hanno completato questa guida.
Un commento
i have a question what does the spring do on the ipod touch 4 gen and is there a replacement spring for it.
