Salta al contenuto principale
iPad Mini Wi-Fi Front Facing Camera Cable Replacement
Andrew Optimus Goldheart
Andrew Optimus Goldheart e 3 altri collaboratori
Ultimo aggiornamento il May 7, 2024
Nessuna stima
Moderato
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
Strumenti
  1. iPad Mini Wi-Fi Front Facing Camera Cable Replacement, Front Facing Camera Cable: passo 1, immagine 1 di 2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement, Front Facing Camera Cable: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers to peel up and remove the small piece of tape covering the front-facing camera cable connector.
  2. iPad Mini Wi-Fi Front Facing Camera Cable Replacement: passo 2, immagine 1 di 2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement: passo 2, immagine 2 di 2
    • The front-facing camera cable connector is secured with pieces of tape that wrap up around the sides of the cable and are fastened to two small metal plates.
    • Use a plastic opening tool to gently pry the lower metal plate up from the front-facing camera cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the front-facing camera cable connector.
  3. iPad Mini Wi-Fi Front Facing Camera Cable Replacement: passo 3, immagine 1 di 2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement: passo 3, immagine 2 di 2
    • Gently pry the second metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the front-facing camera cable connector.
  4. iPad Mini Wi-Fi Front Facing Camera Cable Replacement: passo 4, immagine 1 di 2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board.
  5. iPad Mini Wi-Fi Front Facing Camera Cable Replacement: passo 5, immagine 1 di 2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement: passo 5, immagine 2 di 2
    • Gently fold the front-facing camera cable upwards (roughly at a 90-degree angle), exposing the bottom side of it.
Conclusione
iFixit Membro di iFixit
Staff
118 Membri
19.455 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 46
