Salta al contenuto principale
iPad 3 4G Headphone Jack Assembly Replacement
Brett Hartt
Brett Hartt e 4 altri collaboratori
Ultimo aggiornamento il February 21, 2021
Nessuna stima
Moderato
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Introduzione
Vai al passo 1
Internal Prerequisite guide
Cosa ti serve
Strumenti
  • Phillips #0 Screwdriver
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. iPad 3 4G Headphone Jack Assembly Replacement, Headphone Jack Assembly: passo 1, immagine 1 di 1
    • Peel back and remove the adhesive tape covering the headphone jack assembly.
  2. iPad 3 4G Headphone Jack Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the single 2.6 mm Phillips #0 screw securing the camera cable to the headphone jack assembly.
  3. iPad 3 4G Headphone Jack Assembly Replacement: passo 3, immagine 1 di 3 iPad 3 4G Headphone Jack Assembly Replacement: passo 3, immagine 2 di 3 iPad 3 4G Headphone Jack Assembly Replacement: passo 3, immagine 3 di 3
    • Using the flat end of a spudger, pry the front-facing camera off of its socket on the headphone jack assembly.
    • Without removing the spudger, slide the spudger to the right, releasing the adhesive holding down the camera cable.
  4. iPad 3 4G Headphone Jack Assembly Replacement: passo 4, immagine 1 di 3 iPad 3 4G Headphone Jack Assembly Replacement: passo 4, immagine 2 di 3 iPad 3 4G Headphone Jack Assembly Replacement: passo 4, immagine 3 di 3
    • Using the tip of the spudger, flip up the retaining flap on the microphone cable ZIF connector.
    • Insert the tip of the spudger underneath the microphone ribbon cable, removing it from its ZIF connector.
    • Slide the spudger to the left, releasing the adhesive holding the microphone ribbon cable to the headphone jack assembly.
  5. iPad 3 4G Headphone Jack Assembly Replacement: passo 5, immagine 1 di 1
    • Use the flat end of the spudger to pry up the antenna connector cable out of its socket on the headphone jack assembly board.
  6. iPad 3 4G Headphone Jack Assembly Replacement: passo 6, immagine 1 di 2 iPad 3 4G Headphone Jack Assembly Replacement: passo 6, immagine 2 di 2
    • Flip up the retaining flap securing the volume/power button ribbon cable connector to the headphone jack assembly board.
    • Remove the volume button ribbon cable from its ZIF connector.
  7. iPad 3 4G Headphone Jack Assembly Replacement: passo 7, immagine 1 di 3 iPad 3 4G Headphone Jack Assembly Replacement: passo 7, immagine 2 di 3 iPad 3 4G Headphone Jack Assembly Replacement: passo 7, immagine 3 di 3
    • Remove the following screws from the headphone jack assembly:
    • Five 2.6 mm Phillips #0
    • Two 2.2 mm Wide Head Phillips #00
    • Two 2.6 mm Phillips #00
    • These screws are angled into the aluminum frame. Be sure to hold the screwdriver so that the screwdriver is in line with the screw, to avoid stripping the screw.
  8. iPad 3 4G Headphone Jack Assembly Replacement: passo 8, immagine 1 di 2 iPad 3 4G Headphone Jack Assembly Replacement: passo 8, immagine 2 di 2
    • Holding onto the ribbon cable of the headphone jack assembly, carefully pull the assembly parallel to the iPad, toward the bottom of the device.
  9. iPad 3 4G Headphone Jack Assembly Replacement: passo 9, immagine 1 di 3 iPad 3 4G Headphone Jack Assembly Replacement: passo 9, immagine 2 di 3 iPad 3 4G Headphone Jack Assembly Replacement: passo 9, immagine 3 di 3
    • Grasping the headphone jack assembly with both hands, pull the assembly from the iPad, minding any cables that may get caught.
Conclusione
Brett Hartt
Membro da: 04/12/10
129.827 Reputazione
143 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.453 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 113
