Salta al contenuto principale
iPad 2 Touch Screen Replacement Video tutorial
ZFix
ZFix e 2 altri collaboratori
Ultimo aggiornamento il July 22, 2019
Nessuna stima
Moderato
Guida fornita dalla comunità
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Introduzione
Vai al passo 1
Don't try this if you haven't experience !!!
How to replace / change broken glass / touch screen - Apple iPad2.
See also iPad 2 Wi-Fi EMC 2415 Front Panel Replacement
Please SUBSCRIBE to my channel ツ
Cosa ti serve
Strumenti
Mostra di più…
Panoramica Video
  1. iPad 2 Touch Screen Replacement Video tutorial, Front Panel Assembly: passo 1, immagine 1 di 2 iPad 2 Touch Screen Replacement Video tutorial, Front Panel Assembly: passo 1, immagine 2 di 2
    • Use the edge of a plastic opening tool to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • The retaining flaps are highlighted in red in the second picture.
  2. iPad 2 Touch Screen Replacement Video tutorial: passo 2, immagine 1 di 2 iPad 2 Touch Screen Replacement Video tutorial: passo 2, immagine 2 di 2
    • Use the edge of a plastic opening tool to peel the digitizer cable off the shields on the logic board.
    • Carefully pull the digitizer cable off the adhesive securing it to the side of the rear case.
  3. iPad 2 Touch Screen Replacement Video tutorial: passo 3, immagine 1 di 1
    • Pull the digitizer ribbon cable straight out of its two sockets on the logic board.
  4. iPad 2 Touch Screen Replacement Video tutorial: passo 4, immagine 1 di 2 iPad 2 Touch Screen Replacement Video tutorial: passo 4, immagine 2 di 2
    • In order to remove the front panel assembly, the ribbon cable needs to slide out between the case and the LCD. You'll need to move the LCD to make some room.
    • Be very careful when moving the LCD, and do not attempt to remove it from the iPad—its cable will remain connected while it is rotated over.
    • Lift the LCD from its long edge farthest from the digitizer cable and gently flip it toward the rear case—like closing a book.
    • While holding the LCD up, gently slide the front panel away from the iPad. Be careful not to snag the digitizer cable on the rear case or LCD.
    • Set the LCD back into the body for safekeeping.
Conclusione
Altre 4 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
194.495 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
327 Membri
1.690 Guide realizzate
1Commento della guida
We replaced the screen successfully and it turns on all looks beautiful except the touch screen isn’t working at all—any thoughts? We are beginners
shelley fiedler - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,481
