Introduzione
Replace or upgrade the CPU in your Late 2012 27" iMac. Don't forget to apply a new layer of thermal compound before reassembling your iMac.
Follow our thermal paste guide for instructions on cleaning and preparing the thermal surfaces and applying a new layer of thermal compound onto the CPU and GPU dies.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:iMac Intel 27" Cardboard Service Wedge$4.99
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
Attrezzo utilizzato in questo passaggio:Plastic Cards$2.99
Set the iMac face-up on a table.
Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Begin to lift the top of the display up from the frame.
If there is a wire or cable underneath adhesive tape, always pull the tape off first.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Pull straight up on the SATA data/power cable to disconnect it from the drive.
Disconnect the power supply control cable from the power supply.
Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
Use the flat end of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
Leftmost
Top
Upper right
Lower right
Remove the four 7.5 mm T8 screws from behind the GPU on the logic board.
Insert the flat end of a spudger between the CPU and heat sink.
Gently pry the CPU up by slightly twisting the spudger.
Remove the CPU from the heat sink. Be careful not to touch the contacts.
Replace the backing plate on the motherboard, and hold it in place while you turn the board over so the side with the CPU socket faces up.
Before installing the heat sink, see our thermal paste guide for instructions on cleaning and preparing the thermal surfaces and applying a new layer of thermal compound onto the CPU and GPU dies.
For the VRAM chips surrounding the GPU, install thermal pads or a thick thermal paste such as K5-PRO, rather than regular thermal paste.
The CPU
The GPU
The VRAM chips
The heat sink plates
Align the holes on the CPU section of the heat sink with the pins on the backing plate.
Set the heat sink straight down on the CPU, GPU, and VRAM chips.
Place the spring plate on the backing plate.
Carefully thread one of the CPU heat sink screws slightly into the heat sink so that just a couple threads are engaged.
Press down on the opposite corner of the spring plate from where you just installed a screw.
While holding the corner down, thread another screw into that corner of the heat sink, again just tightening it until a couple threads are engaged.
Repeat the process of pressing down the spring plate and slightly threading in the screws to install the remaining two heat sink screws.
Tighten the screws down a little at a time in the same order that you installed them—in an "X" pattern starting at one corner and then crossing to the opposite corner.
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
Altre 24 persone hanno completato questa guida.
12 Commenti
i am glad i have found this guide. Thank you so much for this guide. But i wonder if i want to upgrade my cpu with i7, which i7 model should i upgrade? And after reassembly do we need to make any setups on osx?
And finally; how we can re-attache the screen? Do we need some kind of glue or what?
hi, does anybody know if the graphics card can be upgraded on imac 27" 2012 (emc no: 2546) ?
No not possible… the GPU is soldered to the PCB…. you can only upgrade by sourcing a new motherboard with a better GPU (and you might as well add a new CPU to that as well….
