Salta al contenuto principale
iMac G3 Model M4984 Logic Board Replacement
Chris Green
Chris Green e 5 altri collaboratori
Ultimo aggiornamento il 6 giu 2025
20 minuti - 1 ora
Facile
Introduzione
Vai al passo 1
The iMac G3 (Tray-Loading)
The iMac G3 was Apple's new G3 all-in-one. It had tons of new features, and removed all old interfaces. It was released in 1998, and sported a 266Mhz, or 333Mhz PowerPC G3. It also came in five colors: tangerine, blueberry, lime, grape, and strawberry. These were known as the "5 Flavors."
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. iMac G3 Model M4984 Logic Board Replacement, Logic Board: passo 1, immagine 1 di 1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Logic Board Replacement: passo 2, immagine 1 di 1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Logic Board Replacement: passo 3, immagine 1 di 3 iMac G3 Model M4984 Logic Board Replacement: passo 3, immagine 2 di 3 iMac G3 Model M4984 Logic Board Replacement: passo 3, immagine 3 di 3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Logic Board Replacement: passo 4, immagine 1 di 3 iMac G3 Model M4984 Logic Board Replacement: passo 4, immagine 2 di 3 iMac G3 Model M4984 Logic Board Replacement: passo 4, immagine 3 di 3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Logic Board Replacement: passo 5, immagine 1 di 3 iMac G3 Model M4984 Logic Board Replacement: passo 5, immagine 2 di 3 iMac G3 Model M4984 Logic Board Replacement: passo 5, immagine 3 di 3
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Logic Board Replacement: passo 6, immagine 1 di 2 iMac G3 Model M4984 Logic Board Replacement: passo 6, immagine 2 di 2
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Logic Board Replacement: passo 7, immagine 1 di 3 iMac G3 Model M4984 Logic Board Replacement: passo 7, immagine 2 di 3 iMac G3 Model M4984 Logic Board Replacement: passo 7, immagine 3 di 3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
    I also recommend users pay attention to how the cables are threaded around the logic board assembly so they can re-thread them the same way when re-inserting the board assembly.
    Mike Henderson - Replica
  8. iMac G3 Model M4984 Logic Board Replacement: passo 8, immagine 1 di 1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
Conclusione
Altre 12 persone hanno completato questa guida.
Chris Green
Membro da: 10/11/09
37.930 Reputazione
49 Guide realizzate
Master Techs Membro di Master Techs
Community
327 Membri
1.702 Guide realizzate
1Commento della guida
Just did this on my Grape 333 Mhz and on my Lime 333 Mhz which come from from the same place. Actually, I'm surprised that the Grape's logic board has a white IrDA connector which its twin doesn't have...
Nicolas Zbinden - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 42
Tutti i Tempi: 19,206
