Salta al contenuto principale
eufy Security SpaceView Monitor Screen Replacement
ZFarley
ZFarley e un altro collaboratore
Ultimo aggiornamento il 22 mag 2025
10 minuti
Moderato
Introduzione
Vai al passo 1
One of the bigger items on the list to repair is the screen. This display takes up much of the real estate of the monitor and thus is important to have in good working order. Fortunately, it is a straightforward repair, involving only the use of a screwdriver, to separate and replace the screen from its housing.
Cosa ti serve
Strumenti
Mostra di più…
  1. eufy Security SpaceView Monitor Screen Replacement, Display Assembly: passo 1, immagine 1 di 2 eufy Security SpaceView Monitor Screen Replacement, Display Assembly: passo 1, immagine 2 di 2
    • Use an opening tool to press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
  2. eufy Security SpaceView Monitor Screen Replacement, Lift the display: passo 2, immagine 1 di 1
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
  3. eufy Security SpaceView Monitor Screen Replacement, Screen: passo 3, immagine 1 di 1
    • Lay the display face down on a table, to expose the back of the screen.
    • Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
    • There are two on each end of the display, and one on each of its longer sides.
  4. eufy Security SpaceView Monitor Screen Replacement: passo 4, immagine 1 di 2 eufy Security SpaceView Monitor Screen Replacement: passo 4, immagine 2 di 2
    • Gently lift the display housing, and set it aside.
    • The housing is ready to have the new display installed.
  5. eufy Security SpaceView Monitor Screen Replacement: passo 5, immagine 1 di 1
    • Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
Conclusione
ZFarley
Membro da: 10/31/23
395 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 Membro di UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G5
3 Membri
12 Guide realizzate
2Commenti sulla guida
Where do you get the replacement screen?
Ronald - Replica
Yes please, where do we get a replacement screen, does it come with a ribbon cable? What is the part number?
Laguna - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 77
Tutti i Tempi: 1,016
