Salta al contenuto principale
Cronologia dell'introduzione: iPad 7 Headphone Jack Replacement
Modifica di Alex Diaz-Kokaisl
Modifica approvata da Alex Diaz-Kokaisl
Prima di
Dopo il
Invariato
Dispositivo
iPad 7 Wi-Fi
Type
replacement
Thing
Headphone Jack
Title
iPad 8 Headphone Jack Replacement
Introduction
Use this guide to replace the headphone jack in your iPad 8.
***For your safety, discharge the battery below 25% before disassembling your iPad.*** This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, [[What to do with a swollen battery|take appropriate precautions|new_window=true]].
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Time Required Min
1 ora
Time Required Max
2 ore
Imageid
Prima di
Dopo il
Difficulty
Difficult
***To reassemble your device, follow these instructions in reverse order.***
Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
Repair didn’t go as planned? Try some [[Troubleshooting Problems After a Repair|basic troubleshooting]], or ask our [link|https://www.ifixit.com/Answers/Device/iPad%208|iPad 8 Answers community] for help.
Author
Public
No
Strumenti
  • Packing Tape x1 added.
  • Safety Glasses x1 added.
  • Deck of Cards x1 added.
  • Polyimide Tape x1 added.
  • Battery Blocker x1 added.
  • Tweezers x1 added.
  • iOpener x1 added.
  • iFixit Opening Picks (Set of 6) x1 added.
  • Suction Handle x1 added.
  • Spudger x1 added.
  • Phillips #00 Screwdriver x1 added.
  • Phillips #000 Screwdriver x1 added.
Passi
Passo #: 1
Prima di
Dopo il
Passo #: 2
Prima di
Dopo il
Passo #: 3
Prima di
Dopo il
Passo #: 4
Prima di
Dopo il
