Salta al contenuto principale
Cronologia dell'introduzione: Draft Inducer Motor Replacement
Modifica di Craig Lloyd
Modifica approvata da Craig Lloyd
Prima di
Dopo il
Invariato
Dispositivo
Carrier
Type
replacement
Thing
Draft Inducer Motor
Title
Introduction
In a gas furnace, the draft inducer is a fan that’s responsible for expelling combustion gases out of the furnace and venting it to the outside. It’s one of the most important component in a gas furnace and it’s usually the first thing that turns on when a heating cycle begins. It also stays running during a heating cycle to provide a constant, steady flow of oxygen for the burners.
When a draft inducer motor stops working, the entire gas furnace will cease operation, so it’s important that you replace it as soon as possible. A loud whining noise is characteristic of a failing draft inducer motor, as the bearings inside are wearing out.
This replacement is being done on a Carrier WeatherMaker 8000TS furnace from 1999. The draft inducer motor and assembly may differ on your specific furnace model.
Time Required Min
Nessuna stima
Time Required Max
Nessuna stima
Imageid
Prima di
Dopo il
Difficulty
Moderate
Author
Public
No
Ricambi
  • Draft Inducer Motor x1 added.
Contrassegni
  • In Progress added.
Passi
Passo #: 1
Prima di
Dopo il
