Salta al contenuto principale
Zoomer Jurassic World Indominus Rex Back Cover Replacement
Anh Le
Anh Le e 2 altri collaboratori
Ultimo aggiornamento il March 17, 2024
Nessuna stima
Facile
Introduzione
Vai al passo 1
Remove the back cover of the Zoomer Jurassic World Indominus Rex to get access to the motherboard, battery and the mechanical systems of the toy.
Cosa ti serve
Strumenti
  1. Zoomer Jurassic World Indominus Rex Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Turn off and unplug Zoomer Jurassic World Indominus Rex from any power source before doing replacements.
    • Remove all eight (8) 9.3mm Phillips screws using Phillips #1 screwdriver.
  2. Zoomer Jurassic World Indominus Rex Back Cover Replacement: passo 2, immagine 1 di 2 Zoomer Jurassic World Indominus Rex Back Cover Replacement: passo 2, immagine 2 di 2
    • Pry apart the back cover of the Jurassic Indominus Rex and the rest of the body using a spudger.
    • Do not take out the back cover immediately as it it still attached to the motherboard by a wire.
  3. Zoomer Jurassic World Indominus Rex Back Cover Replacement: passo 3, immagine 1 di 2 Zoomer Jurassic World Indominus Rex Back Cover Replacement: passo 3, immagine 2 di 2
    • Disconnect the orange wire that connects the motherboard and the back cover.
    • Separate the back cover and the rest of the Zoomer Jurassic World Indominus Rex.
    • Gently press the tab on the side of the orange connector if you are having trouble disconnecting the wire.
Conclusione
Anh Le
Membro da: 01/20/16
504 Reputazione
3 Guide realizzate
USF Tampa, Team 10-3, Remmell Spring 2016 Membro di USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 468
