Salta al contenuto principale
Zoomer Dino Boomer Tail Tip Replacement
Lauren Mannix
Lauren Mannix e 3 altri collaboratori
Ultimo aggiornamento il March 17, 2024
5 minuti
Facile
Introduzione
Vai al passo 1
This guide will assist the reader in replacing the tip of Zoomer Dino Boomer's tail.
Cosa ti serve
Strumenti
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Zoomer Dino Boomer Tail Tip Replacement, Tail Tip: passo 1, immagine 1 di 2 Zoomer Dino Boomer Tail Tip Replacement, Tail Tip: passo 1, immagine 2 di 2
    • Remove the 9.4 mm Phillips #0 screw from the bottom of the tail of Zoomer Dino Boomer.
  2. Zoomer Dino Boomer Tail Tip Replacement: passo 2, immagine 1 di 2 Zoomer Dino Boomer Tail Tip Replacement: passo 2, immagine 2 di 2
    • Use the spudger to pry open the two ridges on the last segment of the tail.
  3. Zoomer Dino Boomer Tail Tip Replacement: passo 3, immagine 1 di 2 Zoomer Dino Boomer Tail Tip Replacement: passo 3, immagine 2 di 2
    • Remove the rubber tail tip from the plastic connector.
Conclusione
USF Tampa, Team 16-1, Wollert Fall 2015 Membro di USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 Membri
10 Guide realizzate
3 Commenti
Where do I buy the replacement tail? Ours broke off!
supportchris - Replica
What about the rest of the tail? The strings on mine came unattached and the whole tail came off. I am unable to successfully get the strings reattached to the end of the tail.
Bob Essl - Replica
Where can I buy a new tail tip for the green dino?
Christopher Baldwin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 5,507
