Salta al contenuto principale
ZTE Boost MAX N9520 Display Assembly Replacement
T3chboii
T3chboii e 4 altri collaboratori
Ultimo aggiornamento il February 7, 2022
Nessuna stima
Moderato
Foto Azione
Necessarie Più Immagini
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This guide will teach you the way to replace the screen on the zte max and show you how to tear it down.
Cosa ti serve
Strumenti
Mostra di più…
  1. ZTE Boost MAX N9520 Display Assembly Replacement, Display Assembly: passo 1, immagine 1 di 2 ZTE Boost MAX N9520 Display Assembly Replacement, Display Assembly: passo 1, immagine 2 di 2
    • JUST LIFT IT UP FROM THE CORNER WITH A FLAT HEAD OR A SIMILAR TOOL FROM THE ONE YOU SEE ON THE PIC
  2. ZTE Boost MAX N9520 Display Assembly Replacement: passo 2, immagine 1 di 1
    • THE YELLOW SCREWS AS SHOWN ON THE PIC WILL AVOID YOUR WARRANTY, JUST USE A PHILLIP SCREWDRIVER TO TAKE OUT THE SCREW.
  3. ZTE Boost MAX N9520 Display Assembly Replacement: passo 3, immagine 1 di 2 ZTE Boost MAX N9520 Display Assembly Replacement: passo 3, immagine 2 di 2
    • LIFT UP THE BACK WITH A FLAT HEAD OR A SIMILAR TOOL TO A FLAT HEAD , SO YOU CAN REMOVE THE BACK COMPLETELY
  4. ZTE Boost MAX N9520 Display Assembly Replacement: passo 4, immagine 1 di 1
    • WITH A PHILLIP SCREW DRIVER REMOVE THOSE OTHER SCREWS.
    • WITH A FLAT HEAD REMOVE THE RIBBONS AND THE BATTERY CONNECTORS
  5. ZTE Boost MAX N9520 Display Assembly Replacement: passo 5, immagine 1 di 2 ZTE Boost MAX N9520 Display Assembly Replacement: passo 5, immagine 2 di 2
    • WITH A HEATING GUN HEAT THE BACK AND FRONT SO THE GLUE CAN BE REMOVED MORE EASILY
    The glue or double-stick tape holding the screen in the screen bezel is concentrated in two strips across the top and bottom of the phone's screen face.
    Only the top 3/4 cm of the screen needs to be warmed to loosen the adhesive.
    RickBerry - Replica
  6. ZTE Boost MAX N9520 Display Assembly Replacement: passo 6, immagine 1 di 2 ZTE Boost MAX N9520 Display Assembly Replacement: passo 6, immagine 2 di 2
    • AFTER YOU APPLY THE ADHESIVE TAPE JUST PUT THE SCREEN ON THE CORRECT POSITION AND MAKE SURE YOU PUSH THE RIBBONS CORRECTLY
    usually your walk troughs are amazing and on point but i found this one to be a bit lacking a got to the point of getting the battery off but i can not figure out how to remove the metal part that is under the battery some more help would be appreciated thank you
    Aaron
    Akelize30@gmail.com
    aaron scheitler - Replica
Conclusione
Altre 34 persone hanno completato questa guida.
T3chboii
Membro da: 07/21/14
1.123 Reputazione
1 Guida realizzata
11Commenti sulla guida
So how do you get the battery connector unplugged?
jeremylester56 - Replica
take a small flat head screw driver stick it under the white connector (from the side that has the red wire) pry upwards and it will come off. its wedged into the plastic encasing. dont stick the Flathead in all the way you might damage the connectors underneath.
h2kwireless -
Use the black tabs stuck on the bottom of the battery to lift the battery up... assuming you have removed all bolts and flat cables as instructed up to this point. when you do this, work it back and forth applying heat from a heat gun or hair dryer. the battery will eventually give way and you can take the entire circuit board and battery and lay it over on its backside next to the screen.
Take your heat gun or blow dryer and apply heat to the volume buttons still stuck to the side of the screen, remove the buttons.
Now apply a great amount of heat, front and back, until it's very warm to the touch, push through the small holes located on the back of the screen housing to apply pressure on the back of the screen. Keep applying pressure to those holes and eventually the screen will start to give way enough to get a spudger in and work the screen the rest of the way out.
Joseph Brewer - Replica
dude I can not get this battery out I'm afraid to apply to much heat to it I don't want the battery to explode on me lol, how much heat can this battery take?
Richard Jackson -
By disassembling will it erase the saved info in the phone?
John - Replica
Not unless u short out the motherboard. But I've done about 1500 or more repairs and I've probably destroyed 1 motherboard in all that time. Generally, if u know what your doing and take ur time there's no data loss.
Monte Davis -
Put adhisive where ? On which side?
maria arredondo duran - Replica
If I are not using precut adhesive you will need to apply adhesive on all four sides of the screen.
Monte Davis -
How do you plug the battery back up
dez da finesser - Replica
Pls where can I source the touch screen/pad mine is broken and I like this phone
uche oscar - Replica
Problem after replacing screen. It turns on and constantly resets
Eleanor Reddig - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 36,183
