Salta al contenuto principale
Xiaomi Mi Pad Rear Case Assembly Replacement
Kiefer Sivitz
Kiefer Sivitz e 4 altri collaboratori
Ultimo aggiornamento il February 8, 2024
1 minuto
Facile
Necessarie Più Immagini
Introduzione
Vai al passo 1
Use this guide to remove the rear case assembly from your Xiaomi Mi Pad.
The plastic back panel needs to be removed before performing any hardware repairs.
Cosa ti serve
Strumenti
  1. Xiaomi Mi Pad Rear Case Assembly Replacement, Rear Case Assembly: passo 1, immagine 1 di 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Rear Case Assembly Replacement: passo 2, immagine 1 di 2 Xiaomi Mi Pad Rear Case Assembly Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 12-5, Blackwell Fall 2015 Membro di USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 59
Tutti i Tempi: 1,518
