Salta al contenuto principale
Xbox 360 Wireless Controller Buttons Replacement
Brett Hartt
Brett Hartt e 5 altri collaboratori
Ultimo aggiornamento il 19 giu 2024
15 minuti
Moderato
Introduzione
Vai al passo 1
Repair or replace faulty buttons on your Xbox 360 wireless controller.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Xbox 360 Wireless Controller Buttons Replacement, Battery: passo 1, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement, Battery: passo 1, immagine 2 di 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Buttons Replacement, Rear Case: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Buttons Replacement: passo 3, immagine 1 di 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    Any recommendation on which set of Security Torx tools to use? I've already purchased 2 kits, one of those being sold as "Xbox controller tools" but the diameter of the head does not fit the hole on the controller and that's critical for the 2 screws on the bottom. The tools must obviously be thinner in diameter and long enough to get there.
    Arnie - Replica
    How to open an XBOX 360 controller without a special screwdriver. http://www.instructables.com/id/How-to-o... Works perfectly.
    Louis - Replica
    A lot of thanks for your comment. It's very usefull
    Echedey -
    I picked up a handy torx key set from Auto Zone. Was about $10, no lose driver bits. has both sizes you need to repair the controller and the console. Here's the link:
    http://www.autozone.com/autozone/accesso...
    FierDancr - Replica
    It doesn't really matter which set of bits you by or what brand makes them, Torx bits (and the security versions of them) are generic & come in standardized sizes. You do not need a special "xbox" tool kit, you just need a size 8 torx security bit, no matter what brand makes the bit/kit. Those types of "specialty kits" are usually just collections of generic bits that you can buy at a hardware store in a regular bit set. The difference is that a general bit set will have bits for screws that a specific item doesn't have in it, whereas a specialty kit will only include bits for the types & sizes of fasteners used in the specified item.
    BTW, with the smaller sizes of torx security bits you can try breaking off the little post in the middle with needlenose pliers or something else that can fit in the there. Even if the post doesn't break off cleanly, it's usually short enough to fit a regular (non security) torx bit in the slot.
    Nerfbomb - Replica
  4. Xbox 360 Wireless Controller Buttons Replacement: passo 4, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement: passo 4, immagine 2 di 2
    Spudger
    $2.99
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller Buttons Replacement: passo 5, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement: passo 5, immagine 2 di 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller Buttons Replacement: passo 6, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement: passo 6, immagine 2 di 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
    The RB / LB bar will fall away easily as you handle the upper case and logic board; just be prepared for it.
    knoxco - Replica
    Good information
    mazvilaa640 - Replica
  7. Xbox 360 Wireless Controller Buttons Replacement, Vibration Motors: passo 7, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement, Vibration Motors: passo 7, immagine 2 di 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller Buttons Replacement: passo 8, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement: passo 8, immagine 2 di 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
    The opposite was true for the controller I just opened. It was the left motor counterweight (as you hold the controller normally) which had more weight. Perhaps it doesn't matter which goes where?
    Bob S - Replica
    For anyone reading this in the future, it does matter. The way you had them originally is the correct way.
    Yado Nada -
  9. Xbox 360 Wireless Controller Buttons Replacement, Logic Board: passo 9, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement, Logic Board: passo 9, immagine 2 di 2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
    What if you're having difficulty taking the logic board out?
    Xander Uchida - Replica
    In my experience with my controller, the logic board lifts out very easily, there are no tabs or fasteners holding it in.
    So, if you're having difficulty taking the logic board out, call a friend with average hand dexterity & motor skills to do it for you.
    Nerfbomb - Replica
    If the controller is a bit old, the center plastic screw holder might have swollen and will need a little stenght to release the logic board.
    RoFixedIt - Replica
  10. Xbox 360 Wireless Controller Buttons Replacement, Buttons: passo 10, immagine 1 di 1
    • Remove the rubber pad from the back of the input buttons.
  11. Xbox 360 Wireless Controller Buttons Replacement: passo 11, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement: passo 11, immagine 2 di 2
    • Using a pair of tweezers, remove the buttons from the front case.
    • A Button
    • B Button
    • X Button
    • Y Button
    • Start Button
    • Select Button
    • Guide Button
  12. Xbox 360 Wireless Controller Buttons Replacement: passo 12, immagine 1 di 1
    • Using a pair of tweezers, lift the home button's LED ring out of the front case of the controller.
    • All of the buttons have tabs that correspond to slots in the front case. This prevents buttons from being placed in the incorrect position or orientation.
Conclusione
Altre 64 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Brett Hartt
Membro da: 04/12/10
130.413 Reputazione
143 Guide realizzate
iFixit Membro di iFixit
Staff
119 Membri
21.819 Guide realizzate
3Commenti sulla guida
Hello I have had an Xbox for about 1-2years and everything has been working fine until the A button on one of my controllers stopped working I don't think it has gunk or anything because I can press it down and it comes back up just that when I press it in screen nothing happens but the other buttons work fine
Saul Escalon - Replica
Thank you for the teardown! My cat has just vomitted on my joystick…. I could have cleaned it now! I appreciate it , thanks…
Nathan St-Onge - Replica
Has anyone ever replaced the spring contacts in the logic board???
BJ Robbins - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 213
Tutti i Tempi: 74,138
