Salta al contenuto principale
Xbox 360 RF Module Replacement
Walter Galan
Walter Galan e 4 altri collaboratori
Ultimo aggiornamento il 10 set 2020
Nessuna stima
Difficile
Introduzione
Vai al passo 1
Use this guide to replace the circuit board housing the status LEDs beneath the power button.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Xbox 360 RF Module Replacement, Hard Drive: passo 1, immagine 1 di 2 Xbox 360 RF Module Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Grasp the hard drive assembly and press the release button while lifting its front edge.
    • Remove the hard drive assembly from the top vent.
    WARNING: Just replacing the drive will not make it work correctly. Microsoft has married the drives to the motherboard. Hence, in order to get full operation out of the drive you'll have to perform more steps not listed here. Search in the FAQ on this specific topic for more details. Otherwise, before buying a new drive, try cleaning the inside of the old one and/or replace the belt involved in opening and closing the drive door.
    - Good Luck
    Eric - Replica
    Thanks..helped!
    joseph zulu - Replica
    bress the button and lift with the same hand! i thought mine was stuck because of this pic!!!
    Maths with Luigi - Replica
  2. Xbox 360 RF Module Replacement, Bottom Vent: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Xbox 360 Opening Tool
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
    You can avoid this step by pulling the front cover off. Just make sure you don't break the springs for the USB bay area.
    Repair Doctor - Replica
    Hello, thank you ifix for this guide, I followed this guide, I got stuck at some point but I resolved it. Also I want to share this resource: Step by Step guide to fix Xbox 360 errors it helped me go through all the things associated with Xbox 360 and the troubleshooting of errors. Hope this can also help you all.
    Christopher Sage - Replica
  3. Xbox 360 RF Module Replacement: passo 3, immagine 1 di 3 Xbox 360 RF Module Replacement: passo 3, immagine 2 di 3 Xbox 360 RF Module Replacement: passo 3, immagine 3 di 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
  4. Xbox 360 RF Module Replacement: passo 4, immagine 1 di 2 Xbox 360 RF Module Replacement: passo 4, immagine 2 di 2
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
  5. Xbox 360 RF Module Replacement: passo 5, immagine 1 di 2 Xbox 360 RF Module Replacement: passo 5, immagine 2 di 2
    • Repeat the same process to release the two center clips on the bottom vent.
  6. Xbox 360 RF Module Replacement: passo 6, immagine 1 di 2 Xbox 360 RF Module Replacement: passo 6, immagine 2 di 2
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
  7. Xbox 360 RF Module Replacement: passo 7, immagine 1 di 1
    • Remove the bottom vent from the 360.
  8. Xbox 360 RF Module Replacement, Faceplate: passo 8, immagine 1 di 2 Xbox 360 RF Module Replacement, Faceplate: passo 8, immagine 2 di 2
    • Insert the flat edge of a spudger between the faceplate and the outer casing near the power button.
    • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
    • You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
    • Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
    The faceplate just pulls off, using a tool is completely unneccessary. https://beta.support.xbox.com/help/xbox-...
    Erik Tomlinson - Replica
  9. Xbox 360 RF Module Replacement: passo 9, immagine 1 di 1
    • Repeat the same motions as previously mentioned to release the left side of the faceplate.
  10. Xbox 360 RF Module Replacement: passo 10, immagine 1 di 1
    • Remove the faceplate from the front face of the console.
  11. Xbox 360 RF Module Replacement, Top Vent: passo 11, immagine 1 di 2 Xbox 360 RF Module Replacement, Top Vent: passo 11, immagine 2 di 2
    • Stand the console vertically with the top edge facing up.
    • The top vent is secured to the console via clips. The first two clips are located underneath the top vent closest to the faceplate, as shown in the pictures.
  12. Xbox 360 RF Module Replacement: passo 12, immagine 1 di 2 Xbox 360 RF Module Replacement: passo 12, immagine 2 di 2
    • Insert the flat end of a spudger into the small gaps previously mentioned to release the clips.
    • You may also use the long finger of an Xbox 360 opening tool to accomplish this task.
    I found it easier to open these clips using the pointy end of the spudger rather than the flat end. Just slide it in against the side of the case and the clip will pop off.
    dave - Replica
    I found this step difficult. I wasn't able to see where the clips were from the pictures. If you look at step 14 you can see what the clips look like after the vent is taken off. Once you realize where they are it is a lot easier.
    Jonathan Crall - Replica
  13. Xbox 360 RF Module Replacement: passo 13, immagine 1 di 3 Xbox 360 RF Module Replacement: passo 13, immagine 2 di 3 Xbox 360 RF Module Replacement: passo 13, immagine 3 di 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the top vent. Their locations are highlighted in red.
  14. Xbox 360 RF Module Replacement: passo 14, immagine 1 di 2 Xbox 360 RF Module Replacement: passo 14, immagine 2 di 2
    • To release the clips, work from the middle of the top vent.
    • While slightly lifting the front edge of the top vent, use the tip of a spudger to push the clips closest to the center of the top vent towards the inside of the console.
  15. Xbox 360 RF Module Replacement: passo 15, immagine 1 di 1
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox's upper case.
  16. Xbox 360 RF Module Replacement: passo 16, immagine 1 di 2 Xbox 360 RF Module Replacement: passo 16, immagine 2 di 2
    • The last clip is hidden underneath the rubber foot nearest the back of the console.
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox.
    • Remove the top vent from the 360.
  17. Xbox 360 RF Module Replacement, Lower Case: passo 17, immagine 1 di 1
    • Stand the console vertically with the top edge facing down.
    • Carefully peel the warranty sticker off the console.
    There is an alternate to breaking the seal. If you open the back first starting with the opposite side of the sticker you can get the rear to "Clam Open" retaining the seal.
    Eric - Replica
    LOL “Romove the warenty seal”
    Alexander Wiand - Replica
  18. Xbox 360 RF Module Replacement: passo 18, immagine 1 di 3 Xbox 360 RF Module Replacement: passo 18, immagine 2 di 3 Xbox 360 RF Module Replacement: passo 18, immagine 3 di 3
    • The upper and lower cases are attached via several latches, located in the front and back of the console. These latches must be disengaged to separate the upper case from the console.
    • Use the flat end of a spudger to release the following latches:
    • Above the front-facing USB ports.
    • Beneath the front-facing USB ports.
    • Above the Memory Unit slots.
  19. Xbox 360 RF Module Replacement: passo 19, immagine 1 di 1
    • Insert the flat end of a spudger and pry upwards to release the last remaining latch located above the eject button.
  20. Xbox 360 RF Module Replacement: passo 20, immagine 1 di 1
    • Slightly lift the front portion of the lower case to ensure that the latches in the front have been completely released.
  21. Xbox 360 RF Module Replacement: passo 21, immagine 1 di 2 Xbox 360 RF Module Replacement: passo 21, immagine 2 di 2
    • The upper and lower cases are held together by seven release latches located on the back of the console. Their locations are highlighted in red.
  22. Xbox 360 RF Module Replacement: passo 22, immagine 1 di 3 Xbox 360 RF Module Replacement: passo 22, immagine 2 di 3 Xbox 360 RF Module Replacement: passo 22, immagine 3 di 3
    • Press the Xbox 360 opening tool down into the clips securing the lower case to the upper case near the I/O ports.
    • While pressing down on the tool, push the lower and upper cases apart to separate the retaining clips.
    I didn't have an XBox tool, so I followed instructions in this video for this step (https://www.youtube.com/watch?v=qaxIB6cX...) to pry it open with your fingers and a screwdriver.
    Nick Karnik - Replica
    The small (metal) women's hair clip is best for un-latching the tabs. The screw drivers just make the holes bigger.
    Denny Ross - Replica
    You can also use the pointed end of a plastic spudger to push each clip free while you separate the case with your free hand.
    Michael Carson - Replica
  23. Xbox 360 RF Module Replacement: passo 23, immagine 1 di 2 Xbox 360 RF Module Replacement: passo 23, immagine 2 di 2
    • While pushing the upper and lower cases apart, use the tip of a spudger or the finger of an Xbox 360 opening tool to push the long clip highlighted in red toward the center of the 360.
    • The clip should release, leaving the clips near the power connector as the only thing holding the upper and lower cases together.
  24. Xbox 360 RF Module Replacement: passo 24, immagine 1 di 1
    • Press the Xbox 360 opening tool down into the two remaining clips near the power connector.
    • Push the upper and lower cases apart to fully release the retaining clips.
  25. Xbox 360 RF Module Replacement: passo 25, immagine 1 di 1
    • Orient the console so that the front portion is facing downwards.
    • Grasp the back portion of the lower case and lift it upwards to separate it from the console.
    • Be careful not to excessively bend the lower case near the power plug, as it can crack easily.
  26. Xbox 360 RF Module Replacement, Eject Button: passo 26, immagine 1 di 2 Xbox 360 RF Module Replacement, Eject Button: passo 26, immagine 2 di 2
    • Use the tip of a spudger to release the clip securing the eject button to the metal casing.
    • Insert the flat end of a spudger between the eject button and the optical drive.
    • Pry the eject button off its retaining posts and remove it from the 360.
    • This can also be accomplished using an Xbox 360 opening tool.
  27. Xbox 360 RF Module Replacement, Upper Case: passo 27, immagine 1 di 1
    • Remove the six silver 64 mm T10 Torx screws securing the upper case to the metal casing.
  28. Xbox 360 RF Module Replacement: passo 28, immagine 1 di 1
    • Orient the console so that the upper case is facing upwards.
    • Lift the upper case straight up and remove it from the console.
  29. Xbox 360 RF Module Replacement, RF Module: passo 29, immagine 1 di 3 Xbox 360 RF Module Replacement, RF Module: passo 29, immagine 2 di 3 Xbox 360 RF Module Replacement, RF Module: passo 29, immagine 3 di 3
    • Use the flat end of a spudger to release the clips securing the plastic RF module shield along the top and the left edge of the power button board.
    • Lift and remove the RF module shield from the console.
  30. Xbox 360 RF Module Replacement: passo 30, immagine 1 di 1
    • Remove three 5.6 mm T8 Torx screws securing the RF module to the metal chassis.
  31. Xbox 360 RF Module Replacement: passo 31, immagine 1 di 2 Xbox 360 RF Module Replacement: passo 31, immagine 2 di 2
    • Grasp the RF module and lift it straight up to disconnect it from its socket on the motherboard.
    • Remove the RF module from the console.
    I can fix it now after reading your article,and I bought Gotor RF board on amazon,it looks good.
    Maybe it can help you.
    1261693729 - Replica
Conclusione
Altre 28 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
1Commento della guida
Just out of curiosity, what does it mean when there is the marking AC above the chipset to the right of the Microsoft logo? Is it a different kind of board? Or just a variant on the console lifetime?
Jonathon Theys - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 43
Tutti i Tempi: 44,909
