Salta al contenuto principale
WowWee MiP Robot Power Switch Replacement
Daniel Burkholder
Daniel Burkholder e 4 altri collaboratori
Ultimo aggiornamento il 19 dic 2023
30 - 45 minuti
Moderato
Introduzione
Vai al passo 1
The power switch turns the MiP on or off. If it's malfunctioning the robot will not work.
Cosa ti serve
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. WowWee MiP Robot Power Switch Replacement, Battery: passo 1, immagine 1 di 2 WowWee MiP Robot Power Switch Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Power Switch Replacement: passo 2, immagine 1 di 2 WowWee MiP Robot Power Switch Replacement: passo 2, immagine 2 di 2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot Power Switch Replacement, Wheel: passo 3, immagine 1 di 2 WowWee MiP Robot Power Switch Replacement, Wheel: passo 3, immagine 2 di 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
    The hubcap won't come out. It's flat & tight. Even a tiny screwdriver for eyeglass repair can not get under it. Any tricks forgetting it out?
    donna.hester7 - Replica
  4. WowWee MiP Robot Power Switch Replacement: passo 4, immagine 1 di 2 WowWee MiP Robot Power Switch Replacement: passo 4, immagine 2 di 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot Power Switch Replacement: passo 5, immagine 1 di 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: passo 6, immagine 1 di 2 WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: passo 6, immagine 2 di 2
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot Power Switch Replacement: passo 7, immagine 1 di 3 WowWee MiP Robot Power Switch Replacement: passo 7, immagine 2 di 3 WowWee MiP Robot Power Switch Replacement: passo 7, immagine 3 di 3
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot Power Switch Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot Power Switch Replacement, Power Switch: passo 9, immagine 1 di 2 WowWee MiP Robot Power Switch Replacement, Power Switch: passo 9, immagine 2 di 2
    • Remove the two 9.3mm Phillips #1 screws.
  10. WowWee MiP Robot Power Switch Replacement: passo 10, immagine 1 di 1
    • Remove the power switch assembly from the body by gently pulling straight out on the wires.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 3-4, Wollert Spring 2016 Membro di USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
4 Membri
10 Guide realizzate
1Commento della guida
where can i buy the power switch of MiP
Reinejoe Cacho - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 684
