Salta al contenuto principale
WowWee MiP Robot LED Light Replacement
Courtney
Courtney e 4 altri collaboratori
Ultimo aggiornamento il May 7, 2024
30 - 45 minuti
Moderato
Introduzione
Vai al passo 1
The LED light on the MiP indicates what mode the robot is in. If this light is malfunctioning, using the MiP is difficult.
Cosa ti serve
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. WowWee MiP Robot LED Light Replacement, Battery: passo 1, immagine 1 di 2 WowWee MiP Robot LED Light Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot LED Light Replacement: passo 2, immagine 1 di 2 WowWee MiP Robot LED Light Replacement: passo 2, immagine 2 di 2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot LED Light Replacement, Wheel: passo 3, immagine 1 di 2 WowWee MiP Robot LED Light Replacement, Wheel: passo 3, immagine 2 di 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  4. WowWee MiP Robot LED Light Replacement: passo 4, immagine 1 di 2 WowWee MiP Robot LED Light Replacement: passo 4, immagine 2 di 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot LED Light Replacement: passo 5, immagine 1 di 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot LED Light Replacement, WowWee MiP Robot Body Disassembly: passo 6, immagine 1 di 2 WowWee MiP Robot LED Light Replacement, WowWee MiP Robot Body Disassembly: passo 6, immagine 2 di 2
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot LED Light Replacement: passo 7, immagine 1 di 3 WowWee MiP Robot LED Light Replacement: passo 7, immagine 2 di 3 WowWee MiP Robot LED Light Replacement: passo 7, immagine 3 di 3
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot LED Light Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot LED Light Replacement, LED Light: passo 9, immagine 1 di 2 WowWee MiP Robot LED Light Replacement, LED Light: passo 9, immagine 2 di 2
    • Remove the four 7.5mm Phillips #1 screws.
  10. WowWee MiP Robot LED Light Replacement: passo 10, immagine 1 di 2 WowWee MiP Robot LED Light Replacement: passo 10, immagine 2 di 2
    • Carefully pull the motor and motherboard assembly straight out from the base.
    • Be careful not to break the plastic rods that go through the motor assembly and are connect to the shell.
  11. WowWee MiP Robot LED Light Replacement: passo 11, immagine 1 di 1
    • Use the precision tweezers to unplug the bundle of wires.
  12. WowWee MiP Robot LED Light Replacement: passo 12, immagine 1 di 1
    • Slide the head back to separate it from the body.
    • The motherboard does not need to be separated from the head to replace the LED light.
  13. WowWee MiP Robot LED Light Replacement: passo 13, immagine 1 di 1
    • Remove the 7.5mm Phillips #1 screw.
    • The LED light is soldered to the small circuit board.
Conclusione
Courtney
Membro da: 02/04/16
236 Reputazione
1 Guida realizzata
USF Tampa, Team 3-4, Wollert Spring 2016 Membro di USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 672
