Windsor Willow Rear Wheel Replacement
Introduzione
Vai al passo 1This guide will walk you through how to replace the rear wheel in case of broken tire or the wheel.
To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
Hold the bicycle so that the bicycle wheels rests in the air and able to stand on its own.
