Salta al contenuto principale
Vizio SmartCast Tablet Remote XR6M Battery Replacement
tate campbell
tate campbell e 4 altri collaboratori
Ultimo aggiornamento il December 10, 2018
5 - 10 minuti
Facile
Introduzione
Vai al passo 1
Problems with charging that cannot be resolved by using a different charger may necessitate battery replacement. Here you will find a simple, step-by-step guide to take apart the tablet on your own, and remove and replace the battery.
Cosa ti serve
Strumenti
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
Mostra di più…
  1. Vizio SmartCast Tablet Remote XR6M Battery Replacement, Battery: passo 1, immagine 1 di 3 Vizio SmartCast Tablet Remote XR6M Battery Replacement, Battery: passo 1, immagine 2 di 3 Vizio SmartCast Tablet Remote XR6M Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Hold the device in one hand with the screen facing down.
    • Insert the plastic opening tool under the back panel on the side of the device.
    • Slide the plastic opening tool down the side of the device, then repeat this process on all four sides of the device until the back panel pops off.
    • You may hear a popping noise when you pry off the back panel.
  2. Vizio SmartCast Tablet Remote XR6M Battery Replacement: passo 2, immagine 1 di 3 Vizio SmartCast Tablet Remote XR6M Battery Replacement: passo 2, immagine 2 di 3 Vizio SmartCast Tablet Remote XR6M Battery Replacement: passo 2, immagine 3 di 3
    • Use a driver with the T5 bit to remove the 3mm screws attaching the narrow metal plate to the main board.
  3. Vizio SmartCast Tablet Remote XR6M Battery Replacement: passo 3, immagine 1 di 2 Vizio SmartCast Tablet Remote XR6M Battery Replacement: passo 3, immagine 2 di 2
    • Slide the pointy end of the nylon spudger under the wires of the battery connector, and gently lift the wires away from the device, freeing the connector from the main board.
  4. Vizio SmartCast Tablet Remote XR6M Battery Replacement: passo 4, immagine 1 di 2 Vizio SmartCast Tablet Remote XR6M Battery Replacement: passo 4, immagine 2 di 2
    • To remove adhesive, insert the flat end of the plastic spudger under the battery. Slide it toward the top of the device until the battery pops free.
    • You may hear a popping noise when you pry off the battery.
    Hello, my name is Wesley and I would like to know where I can buy a battery for this type of control. My number is (407)907-3273
    assessoriawesley@gmail.com - Replica
Conclusione
Altre 7 persone hanno completato questa guida.
4Commenti sulla guida
Where did you find the replacement battery? I’ve looked everywhere, but the part numbers bring up nothing.
John - Replica
Same as that guy ^^^
gary goodnight - Replica
Yep me too , where can I get the battery ?????
Minus 300 points
Kyle Parker - Replica
More than 6 years and still no response on where to get the replacement 😔
Ryan Alexander - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,068
