Salta al contenuto principale
VanMoof No 3 -  Upgrade to 8-speed gear
Martin Hampton
Martin Hampton e 2 altri collaboratori
Ultimo aggiornamento il June 26, 2024
2 ore
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
VanMoof's are fantastic-looking bikes but quite heavy and I found the 3-speed gear way too over-geared for the hills here in Sydney. Converting to an 8-speed suddenly made my bike much more usable.
It's really important you get the correct hub gear (36 spoke, with coaster brake) - I brought the wrong one first so don't make my mistake! Gears last for a long time so I was happy to use a second-hand one.
Spreading the dropout to take the new gear was a concern so I had this done at a bike store and there's no evidence of damage.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. VanMoof No 3 -  Upgrade to 8-speed gear, What you'll need: passo 1, immagine 1 di 1
    • Shimano SG-C6001-8C Nexus 8. This is the one with the coaster brake.
    • Chain ring, gear lever, seals, and clips
    • Shimano Grip Shifter Nexus 8-speed Sl-C60008
    • Gear cable (inner and outer)
    • Spokes 36 * 284mm stainless steel spokes
  2. VanMoof No 3 -  Upgrade to 8-speed gear, Double check your spoke length: passo 2, immagine 1 di 1
    • Measure the inside diameter of your wheel
    • Use this calculator https://leonard.io/edd/
    • Add 2mm. You should get 284mm spokes
    • I brought silver Halo spokes from ebay. They are decent quality and have not rusted.
    • You need to stretch the rear frame dropouts because the 8-speed hub is wider (135mm) than the 3-speed one (110mm)
    • I got my local bike shop to do this because there's a risk for damaging your frame.
    • The cost was $150 AUD
  3. VanMoof No 3 -  Upgrade to 8-speed gear, Replace the spokes: passo 4, immagine 1 di 2 VanMoof No 3 -  Upgrade to 8-speed gear, Replace the spokes: passo 4, immagine 2 di 2
    • Remove all the old spokes from your wheel
    • Spoke the 8 speed gear into the wheel. This is the best guide https://www.youtube.com/watch?v=mIU6mi0K...
    • Tighten all the spokes using a screwdriver. Use the same torque on the screwdriver and check by "plucking" the spokes so they sound the same
    • Turn the bike upside down, install the wheel, and true the wheel. I hold a screwdriver against the frame and slowly spin the wheel. When it moves in, I just tighten the opposite spokes
  4. VanMoof No 3 -  Upgrade to 8-speed gear, Install back wheel and cable: passo 5, immagine 1 di 1
    • Pull the old inner cable out from the front
    • Push the new inner cable into the old outer cable
    • Pull the old outer gear cable out of the back of the bottom of the frame. LEAVE THE INNER CABLE IN so you can use it as a guide through the frame.
    • Push the new outer cable in from the back
  5. VanMoof No 3 -  Upgrade to 8-speed gear, Replace the gear twist: passo 6, immagine 1 di 1
    • Remove the handlebar grip. I pushed a spoke between the grip and the bar and rolled the spoke to loosen the grip
    • Install new gear change
    • Replace the handle bar grip. I wiped the handle bar and inside grip with alcohol.
    • Connect the gear cable.
    • Use a spoke to rotate the gear change
Linea Traguardo
Martin Hampton
Membro da: 02/13/16
1.308 Reputazione
7 Guide realizzate
2 Commenti
Would this be a possible solution for a bike with a broken eshifter? I have an x3 with err44 and cannot find a replacement part.
Jon Stewart - Replica
I've seen a few e-shifters for sale on facebook, and there are guides on how to fix the electronics so I'd probably go that route. The main problem I can think of with changing to the 8 speed is you'll need to deal with e-shifter wire and you'll need to route the gear change cable on frame. Good luck!
Martin Hampton -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 33
Tutti i Tempi: 2,398
