VTech VM3254 Battery Replacement
Introduzione
Vai al passo 1If the VTech VM3245 will not switch on, the battery may need to be replaced. The information below specifically states how to remove the battery and replace it with a new one. The only tools needed include a Phillips #00 screwdriver, Jimmy, and one opening pick. You will not have any difficult steps, but remove the front cover of the device attentively.
Cosa ti serve
Strumenti
Mostra di più…
Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
Gently remove the battery from its location.
Carefully disconnect the bundled cable connector from the circuit board.
Wo finde ich denn genau solch eine Batterie ?
Besten Gruß
René
kroenung1990@googlemail.com
