Salta al contenuto principale
UE BOOM 2 Micro-USB Port Replacement
Alex Bahm
Alex Bahm e un altro collaboratore
Ultimo aggiornamento il 17 lug 2023
10 - 20 minuti
Moderato
Introduzione
Vai al passo 1
The micro-USB port is located under a rubber cover on the bottom of the UE Boom 2 speaker. Replacing this part requires the removal of the D-ring and rubber port cover, In addition the bottom pad must be removed, which will void the device warranty.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: passo 1, immagine 1 di 2 UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: passo 1, immagine 2 di 2
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Micro-USB Port Replacement: passo 2, immagine 1 di 2 UE BOOM 2 Micro-USB Port Replacement: passo 2, immagine 2 di 2
    • After the D-ring has been removed, the rubber port cover can be removed.
  3. UE BOOM 2 Micro-USB Port Replacement: passo 3, immagine 1 di 3 UE BOOM 2 Micro-USB Port Replacement: passo 3, immagine 2 di 3 UE BOOM 2 Micro-USB Port Replacement: passo 3, immagine 3 di 3
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
    The rubber is glued to a hard plastic part of the case that is snapped in. Must remove the hard plastic that the rubber is attached to. Not just the rubber.
    Jordan Baxter (jbax92) - Replica
  4. UE BOOM 2 Micro-USB Port Replacement: passo 4, immagine 1 di 1
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Micro-USB Port Replacement: passo 5, immagine 1 di 3 UE BOOM 2 Micro-USB Port Replacement: passo 5, immagine 2 di 3 UE BOOM 2 Micro-USB Port Replacement: passo 5, immagine 3 di 3
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
    • Pry up at the location marked, and remove the plastic end cap.
    • The white plastic section houses the USB micro B, and must be replaced as a whole.
Conclusione
Altre 8 persone hanno completato questa guida.
Alex Bahm
Membro da: 01/18/18
2.311 Reputazione
6 Guide realizzate
Cal Poly, Team S12-G5, Banghart Winter 2018 Membro di Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 Membri
15 Guide realizzate
6Commenti sulla guida
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - Replica
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - Replica
i too am looking to find the replacement part
Liam Nicholls - Replica
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
https://www.joesge.com/products/micro-us...
Roger Burke - Replica
Anyone have the part number to convert it to a USB type c instead of A?
vdub_corrado - Replica
I want to have the UE Boom 2
Fixed because it stopped charging while plugging my UE Boom 2
Shannon Leclair - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 81
Tutti i Tempi: 9,984
