Salta al contenuto principale
Turtle Beach Recon Controller Front Buttons Replacement
Cosa ti serve
  1. Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: passo 1, immagine 1 di 3 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: passo 1, immagine 2 di 3 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: passo 1, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
  2. Turtle Beach Recon Controller Front Buttons Replacement: passo 2, immagine 1 di 3 Turtle Beach Recon Controller Front Buttons Replacement: passo 2, immagine 2 di 3 Turtle Beach Recon Controller Front Buttons Replacement: passo 2, immagine 3 di 3
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
  3. Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: passo 3, immagine 1 di 2 Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: passo 3, immagine 2 di 2
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
  4. Turtle Beach Recon Controller Front Buttons Replacement: passo 4, immagine 1 di 2 Turtle Beach Recon Controller Front Buttons Replacement: passo 4, immagine 2 di 2
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
  5. Turtle Beach Recon Controller Front Buttons Replacement: passo 5, immagine 1 di 3 Turtle Beach Recon Controller Front Buttons Replacement: passo 5, immagine 2 di 3 Turtle Beach Recon Controller Front Buttons Replacement: passo 5, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
  6. Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: passo 6, immagine 1 di 3 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: passo 6, immagine 2 di 3 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: passo 6, immagine 3 di 3
    • Gently remove front buttons from the face plate by hand.
Conclusione
Mary Goodrow
Membro da: 03/22/24
671 Reputazione
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 28
Tutti i Tempi: 433
