Salta al contenuto principale
Trek 820 Tail Light Mounting Bracket Replacement
Kaveh Karimiyanha
Kaveh Karimiyanha e 6 altri collaboratori
Ultimo aggiornamento il October 30, 2014
5 minuti
Facile
Necessarie Immagini Migliori
Introduzione Migliore
Cosa ti serve
  1. Trek 820 Tail Light Mounting Bracket Replacement, Tail Light Mounting Bracket: passo 1, immagine 1 di 1
    • Obtain one tail light mounting bracket and one screw as shown in the picture.
    • The screw should be removed from the mounting bracket.
  2. Trek 820 Tail Light Mounting Bracket Replacement: passo 2, immagine 1 di 1
    • Clean the bicycle seat post and mounting bracket.
    • Wrap the mounting bracket strap around the seat post.
    • Verify the larger piece rests towards the tail end aligned with the tires.
    • Verify the bracket's screw hole is on the right side of the bicycle.
  3. Trek 820 Tail Light Mounting Bracket Replacement: passo 3, immagine 1 di 2 Trek 820 Tail Light Mounting Bracket Replacement: passo 3, immagine 2 di 2
    • Locate the slot on the bracket where the strap will be inserted.
    • Insert the strap into the slot.
    • Tighten the strap just enough to keep the bracket in place.
  4. Trek 820 Tail Light Mounting Bracket Replacement: passo 4, immagine 1 di 2 Trek 820 Tail Light Mounting Bracket Replacement: passo 4, immagine 2 di 2
    • Insert the screw into the bracket screw hole.
    • Tighten the screw with fingers until the mounting bracket rests freely on seat post.
Conclusione
Cal Poly, Team 1-1, Propen Fall 2012 Membro di Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,144
