Salta al contenuto principale
Toshiba TECRA R940 Hard Drive Replacement
Holly Strauch
Holly Strauch e 3 altri collaboratori
Ultimo aggiornamento il March 19, 2023
5 minuti
Facile
Introduzione
Vai al passo 1
The hard drive is one of the most simple part replacements to perform on this computer. A screwdriver and prying tool are the only tools needed.
Cosa ti serve
Strumenti
  1. Toshiba TECRA R940 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 Toshiba TECRA R940 Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Loosen the screw holding the back panel for RAM in place using a Phillips #0 screwdriver. Once loosened, lift the panel up and set it aside.
    • The screw holding the panel in place should not come completely out. If it does, do not be alarmed as it will still screw back in.
  2. Toshiba TECRA R940 Hard Drive Replacement: passo 2, immagine 1 di 2 Toshiba TECRA R940 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Remove the 11mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  3. Toshiba TECRA R940 Hard Drive Replacement: passo 3, immagine 1 di 2 Toshiba TECRA R940 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Gently lift the hard drive from the left side and disconnect the SATA connector from the right side. Completely remove the hard drive.
Conclusione
Un commento
I cannot lift up the “back cover” (step 1). I’ve twirled the screw left for minutes and tried to lift up the panel using a small flathead screwdriver and it will not lift up. HELP!
Remy Secor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,152
