Salta al contenuto principale
Toshiba Satellite p875 s7200 RAM Stick Replacement
Danny Amado
Danny Amado e 2 altri collaboratori
Ultimo aggiornamento il December 13, 2018
20 minuti
Moderato
Foto Azione
Introduzione
Vai al passo 1
If you need to replace the RAM stick, follow this guide. The RAM stick can be accessed from the bottom of the computer. To replace this part, you will need a Phillips 0 screw driver and a plastic prying tool.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Toshiba Satellite p875 s7200 RAM Stick Replacement, RAM Stick: passo 1, immagine 1 di 1
    • Remove the battery by sliding the tabs to the left.
    • Use the spudger to lift the battery out.
  2. Toshiba Satellite p875 s7200 RAM Stick Replacement: passo 2, immagine 1 di 1
    • Use the Phillips head screw driver to remove the screw holding the back plate on.
    • Use the spudger to remove the back plate.
  3. Toshiba Satellite p875 s7200 RAM Stick Replacement: passo 3, immagine 1 di 1
    • Unlock the RAM by lightly pushing the two metallic holding arms away from the RAM stick.
    • The holding arms can be pressed together or one at a time.
    • The RAM sticks one of its edges slightly away away from the computer when unlocked.
  4. Toshiba Satellite p875 s7200 RAM Stick Replacement: passo 4, immagine 1 di 1
    • Grab the RAM stick by the protruding edge.
    • Pull the RAM stick towards the right to remove.
Conclusione
Danny Amado
Membro da: 10/29/18
823 Reputazione
5 Guide realizzate
Baylor, Team S1-G3, Williams Fall 2018 Membro di Baylor, Team S1-G3, Williams Fall 2018
BU-WILLIAMS-F18S1G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 398
