Toshiba Satellite U925T-S2120 Hard Drive Replacement
Introduzione
Vai al passo 1Your hard drive stores and retrieves all memory on your laptop. In this guide you will learn how to remove the hard drive of your Toshiba Satellite U925T-S2120. If your hard drive is broken, you may need to replace it. Prior to beginning this guide you should have all required tools that are listed.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use tweezers to pinch and pull out and remove the nine rubber gripper pads on the back panel of the laptop. Set aside.
Altre 2 persone hanno completato questa guida.
