Salta al contenuto principale
Toshiba Satellite S55t-C5225 RAM Replacement
Javien Delgado
Javien Delgado e 3 altri collaboratori
Ultimo aggiornamento il March 12, 2023
5 - 15 minuti
Moderato
Introduzione Migliore
Introduzione
Vai al passo 1
If your Toshiba Satellite S55t-C5225 shuts down abruptly, performance is low, or fails to install new programs then the RAM most likely needs to be replaced. The following guide will walk the user through replacing the RAM in your Toshiba Satellite S55t-C5225.
Cosa ti serve
Strumenti
  1. Toshiba Satellite S55t-C5225 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 RAM Replacement: passo 2, immagine 1 di 2 Toshiba Satellite S55t-C5225 RAM Replacement: passo 2, immagine 2 di 2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 RAM Replacement: passo 3, immagine 1 di 2 Toshiba Satellite S55t-C5225 RAM Replacement: passo 3, immagine 2 di 2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 RAM Replacement, Back Panel: passo 4, immagine 1 di 2 Toshiba Satellite S55t-C5225 RAM Replacement, Back Panel: passo 4, immagine 2 di 2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
    Hi, do you maybe have any instructions on which screw Goes where? I have it all mixed up..
    unatuu - Replica
  5. Toshiba Satellite S55t-C5225 RAM Replacement: passo 5, immagine 1 di 2 Toshiba Satellite S55t-C5225 RAM Replacement: passo 5, immagine 2 di 2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 RAM Replacement: passo 6, immagine 1 di 2 Toshiba Satellite S55t-C5225 RAM Replacement: passo 6, immagine 2 di 2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 RAM Replacement, RAM: passo 7, immagine 1 di 3 Toshiba Satellite S55t-C5225 RAM Replacement, RAM: passo 7, immagine 2 di 3 Toshiba Satellite S55t-C5225 RAM Replacement, RAM: passo 7, immagine 3 di 3
    • Press on the metals clips on the outside of the RAM to release it.
    • Gently pull out the first RAM stick. Repeat the process for the other RAM stick.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Est ce que on remplacer une ram de 4 par une autre de 8
Sadek - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 506
